• Hardware Platform (GPU): Tesla T4
• DeepStream Version: 6.2
• TensorRT Version: 8.5.2.2-1+cuda11.8
• NVIDIA GPU Driver Version: 515.65.01
• Issue Type: Question
We have a custom onnx FP32 model. We are trying to convert it to tensorrt FP16. We are converting the model with this command.
/usr/src/tensorrt/bin/trtexec --fp16 --minShapes=input:1x3x480x640 --optShapes=input:32x3x480x640 --maxShapes=input:32x3x480x640 --onnx='/model.onnx' --saveEngine='model_b16.plan' --workspace=7000
While we check model_b16.plan with this flag (–loadEngine), It is showing FP32. It’s not converting in FP16.
So, Kindly guide us on how we can convert our custom onnx FP32 model into tensorrt FP16.
Thanks,
Dax Jain
yingliu
February 25, 2023, 4:34am
2
Moving to TensorRT forum for better support.
@yingliu and Nvidia support team,
Kindly give us your thought on this raised query.
Hi @daxjain987 ,
Any model can be converted to TRT FP16 by setting builder flag to use FP16
Are you using custom onnx operator? If yes, you will need to implement TRT plugin.
Yes, We did that.
Kindly look at that command which I have mentioned. We have followed the same.
No, we don’t.
We have used Tensorrt from this link
Hello @AakankshaS ,
We are trying to convert the model.onnx FP32 to a model.plan FP16. And for that, we are using “trtexec” for FP16 model conversion.
While we check the precision of the converted FP16 model using “–loadEngine” flag, it’s showing us FP32 only.
Kindly let us know how to convert our model to FP16 or FP32+FP16 precision only.
Dax Jain
Hi @daxjain987 ,
Can you share the onnx model with us, so that we can try reproducing the issue from our end?
Hi @AakankshaS ,
You can download the model from here.
We have tried this model to covert it in the FP16 model with this command
/usr/src/tensorrt/bin/trtexec --fp16 --minShapes=input_1:0:1x416x416x3 --optShapes=input_1:0:32x416x416x3 --maxShapes=input_1:0:32x416x416x3 --onnx='yolov4.onnx' --saveEngine='model_b32.plan' --workspace=7000
After this conversion, we checked this model with the below command
/usr/src/tensorrt/bin/trtexec --loadEngine=model_b32.plan --dumpLayerInfo
We are getting FP32 precision in logs.
Kindly help us to convert the YOLOv4.onnx model to TRT FP16 model conversion.
Thanks,
Dax Jain
Hi @AakankshaS ,
Have you checked the above-highlighted issue?
Looking for your prompt response!!!
Thanks,
Dax Jain
