Description
It works fine when converting a int32 onnx model to a int32 tensorrt engine, but it does not work when trying to convert a fp16 onnx model to a fp16 tensorrt engine. Mind you I’m using yolov5 and from the author “I see the exported model is using Cast modules to FP32 here, probaby on grid addition to the outputs. It seems the .half() cast is not affecting the grid/anchor_grid.”
Log when doing int32 conversion
[11/21/2022-10:44:19] [TRT] [W] onnx2trt_utils.cpp:369: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[11/21/2022-10:44:19] [TRT] [W] onnx2trt_utils.cpp:395: One or more weights outside the range of INT32 was clamped
tensorrt_conversion.py:110: DeprecationWarning: Use build_serialized_network instead.
engine = builder.build_engine(network, config)
[11/21/2022-10:46:32] [TRT] [W] The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
[11/21/2022-11:09:55] [TRT] [W] onnx2trt_utils.cpp:369: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[11/21/2022-11:09:55] [TRT] [W] onnx2trt_utils.cpp:395: One or more weights outside the range of INT32 was clamped
Segmentation fault
Environment
**TensorRT Version = 8.4.3.1 **:
GPU Type = RTX Geforce 3070 Laptop GPU:
Nvidia Driver Version = 517.40:
CUDA Version:
CUDNN Version = 11.7:
Operating System + Version = WSL2 Ubuntu 18.04:
Python Version (if applicable) 3.8.10:
Relevant Files
logger = trt.Logger(trt.Logger.WARNING)
builder = trt.Builder(logger)#Builder object
network = builder.create_network(1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH))
parser = trt.OnnxParser(network, logger)
success = parser.parse_from_file(f"{onnx_file}")
for idx in range(parser.num_errors):
print(parser.get_error(idx))
if not success:
raise RuntimeError (f"failed to load ONNX file: {onnx_file}")
config = builder.create_builder_config()#IBuilderConfig object
config.set_memory_pool_limit(trt.MemoryPoolType.WORKSPACE, 4 << 30)
if not builder..platform_has_fast_fp16:
config.set_flag(trt.BuilderFlag.FP16)
engine = builder.build_serialized_network(network, config)
serialized_engine = engine.serialize()
