Hello.
I am trying to convert my model to FP16 TensorRT.
My process is PyTorch to TensorRT.
I got success in PyTorch to ONNX.
However, the rest still got a problem.
My coversion code is
import os
import sys
c_folder = os.path.abspath(os.path.dirname(__file__))
p_folder = os.path.abspath(os.path.dirname(c_folder))
sys.path.append(c_folder)
sys.path.append(p_folder)
import argparse
import tensorrt as trt
def fp16_convert_main(args):
"""trt settings"""
trt_logger = trt.Logger()
builder = trt.Builder(trt_logger)
network_flags = 0
if args['explicit_batch']:
network_flags |= 1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
if args['explicit_precision']:
network_flags |= 1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_PRECISION)
network = builder.create_network(network_flags)
trt_parser = trt.OnnxParser(network, trt_logger)
"""Parse ONNX"""
with open(args['onnx_file_path'], 'rb') as onnx_model:
print('[INFO] Beginning ONNX file parsing')
trt_parser.parse(onnx_model.read())
print('[INFO] Completed parsing of ONNX file')
"""allow TensorRT to use up to 1GB of GPU memory for tactic selection"""
builder.max_workspace_size = 1 << 30
"""we have only one image in batch"""
builder.max_batch_size = 5
"""select FP16 mode if possible"""
if builder.platform_has_fast_fp16:
builder.fp16_mode = True
"""generate TensorRT engine optimized for the target platform"""
print('[INFO] Building an engine...')
# network.mark_output(network.get_layer(network.num_layers).get_output(0))
engine = builder.build_cuda_engine(network)
context = engine.create_execution_context()
print("[INFO] Completed creating Engine")
"""save built engine"""
folder_path = os.path.split(args['trt_engine_save_path'])[0]
if not os.path.exists(folder_path):
os.makedirs(folder_path)
with open(args['trt_engine_save_path'], 'wb') as f:
f.write(engine.serialize())
return None
if __name__ == "__main__":
parser = argparse.ArgumentParser()
parser.add_argument("--onnx_file_path", default=os.path.join(c_folder, 'mobilenet0.25_Final.onnx'), type=str, help='Path of the onnx file.')
parser.add_argument("--trt_engine_save_path", default=os.path.join(c_folder, 'mobilenet0.25_Final.trt'))
parser.add_argument("--select_mode", default="fp16", type=str, help="Select mode type of trt engine. (Currently, only fp16 is available.)")
parser.add_argument("--explicit_batch", default=True, help="Set trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH.")
parser.add_argument("--explicit_precision", default=False, help="Set trt.NetworkDefinitionCreationFlag.EXPLICIT_PRECISION.")
args = vars(parser.parse_args())
and Get error like
[TensorRT] WARNING: onnx2trt_utils.cpp:198: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[INFO] Building an engine…
[TensorRT] ERROR: Network must have at least one output
[TensorRT] ERROR: Network validation failed.
If you need my model, please let me know.
For more your information, my model’s backbone is mobilenet and I am using the docker image, nvcr.io/nvidia/tensorrt:20.03-py3
