Description
The issue I am facing is that when I try to convert one ONNX file, named “AP.onnx,” it is successfully converted to TensorRT format. However, when I attempt to convert another RGB.onnx file, the conversion process fails.To address the issue, I have attached both the RGB.onnx file, AP.onnx,and attached error message as error.txt at the end.
The error says that fp16 is not configured in the builder
Environment
TensorRT Version: 8.4.1
GPU Type: NVIDIA GeForce RTX 3050
Nvidia Driver Version: 532.03
CUDA Version: 11.7
CUDNN Version: 8.5
Operating System + Version: Ubuntu 20.04 in wsl2 on windows 11
Python Version (if applicable): 3.8.10
Error.txt (726 Bytes)
test.py (2.2 KB)
Steps To Reproduce
- Run the test.py file using python3
AP.onnx (1.3 MB)
RGB_9d9bb888-6342-466a-8705-cf3e7e99677e_2021-07-08_21-37-00.onnx (12.9 MB)
