Conversion from ONNX to TensorRT fails
Description
My model is failing when converting from onnx to tensorrt with the following message ‘Builder timing cache: created 0 entries, 0 hit(s)
../builder/cudnnBuilder2.cpp (2025) - Assertion Error in getSupportedFormats: 0 (!formats.empty())
create engine failed
Aborted (core dumped)’
Environment
TensorRT Version: 7.1.3
GPU Type: 2080ti
Nvidia Driver Version: 460.39
CUDA Version: 11.2
CUDNN Version: 8.0.0
Operating System + Version: ubuntu 18.04
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
running script specified in here: BiSeNet/tensorrt at master · CoinCheung/BiSeNet · GitHub
Steps To Reproduce
please use my onnx model if possible to convert to tensorrt.Please ask me for model if needed.
Hi, Request you to share the ONNX model and the script so that we can assist you better.
Alongside you can try validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
Alternatively, you can try running your model with trtexec command.
https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
