I created network with one convolution layer and use same weights for tensorrt and pytorch.
When I use float32 results are almost equal.
But when I use float16 in tensorrt I got float32 in the output and different results.
Tested on Jetson TX2 and Tesla P100.
import torch
from torch import nn
import numpy as np
import tensorrt as trt
import pycuda.driver as cuda
import pycuda.autoinit
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
class PytorchModel(nn.Module):
def __init__(self, weights):
super().__init__()
self.conv = nn.Conv2d(1, 2, kernel_size=(3, 3), bias=False)
self.conv.weight.data = torch.Tensor(weights)
def forward(self, x):
x = self.conv(x)
return x
def calc_pytorch(data, weights, use_fp16):
if use_fp16:
np_dtype = np.float16
else:
np_dtype = np.float32
data = data.astype(dtype=np_dtype)
weights = weights.astype(dtype=np_dtype)
model = PytorchModel(weights)
model.eval()
model.to('cuda')
if use_fp16:
model.half()
data = torch.Tensor(data)
data = data.unsqueeze(dim=0)
data = data.to('cuda')
if use_fp16:
data = data.half()
with torch.no_grad():
output = model(data).cpu().numpy()
output = output.ravel()
return output
# Simple helper data class that's a little nicer to use than a 2-tuple.
class HostDeviceMem(object):
def __init__(self, host_mem, device_mem):
self.host = host_mem
self.device = device_mem
def __str__(self):
return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
def __repr__(self):
return self.__str__()
# Allocates all buffers required for an engine, i.e. host/device inputs/outputs.
def allocate_buffers(engine):
inputs = []
outputs = []
bindings = []
stream = cuda.Stream()
for binding in engine:
size = trt.volume(engine.get_binding_shape(binding)) * engine.max_batch_size
dtype = trt.nptype(engine.get_binding_dtype(binding))
# Allocate host and device buffers
host_mem = cuda.pagelocked_empty(size, dtype)
device_mem = cuda.mem_alloc(host_mem.nbytes)
# Append the device buffer to device bindings.
bindings.append(int(device_mem))
# Append to the appropriate list.
if engine.binding_is_input(binding):
inputs.append(HostDeviceMem(host_mem, device_mem))
else:
outputs.append(HostDeviceMem(host_mem, device_mem))
print('output engine.get_binding_dtype(binding)', engine.get_binding_dtype(binding))
return inputs, outputs, bindings, stream
# This function is generalized for multiple inputs/outputs.
# inputs and outputs are expected to be lists of HostDeviceMem objects.
def do_inference(context, bindings, inputs, outputs, stream, batch_size=1):
# Transfer input data to the GPU.
[cuda.memcpy_htod_async(inp.device, inp.host, stream) for inp in inputs]
# Run inference.
context.execute_async(batch_size=batch_size, bindings=bindings, stream_handle=stream.handle)
# Transfer predictions back from the GPU.
[cuda.memcpy_dtoh_async(out.host, out.device, stream) for out in outputs]
# Synchronize the stream
stream.synchronize()
# Return only the host outputs.
return [out.host for out in outputs]
def GiB(val):
return val * 1 << 30
def build_engine(weights, use_fp16):
if use_fp16:
trt_dtype = trt.float16
else:
trt_dtype = trt.float32
with trt.Builder(TRT_LOGGER) as builder, builder.create_network() as network:
if use_fp16:
builder.fp16_mode = True
builder.strict_type_constraints = True
print('builder.platform_has_fast_fp16', builder.platform_has_fast_fp16)
print('builder.fp16_mode', builder.fp16_mode)
builder.max_workspace_size = GiB(1)
input_tensor = network.add_input(name='input', dtype=trt_dtype, shape=[1, 3, 3])
input_tensor.name = 'input'
print('input_tensor.dtype', input_tensor.dtype)
conv_w = trt.Weights(weights)
print('conv_w.dtype', conv_w.dtype)
conv_b = trt.Weights(type=trt_dtype)
print('conv_b.dtype', conv_b.dtype)
conv = network.add_convolution(input=input_tensor, num_output_maps=2,
kernel_shape=(3, 3),
kernel=conv_w, bias=conv_b)
conv.precision = trt_dtype
network.mark_output(tensor=conv.get_output(0))
return builder.build_cuda_engine(network)
def calc_tensorrt(data, weights, use_fp16):
if use_fp16:
else:
with build_engine(weights, use_fp16) as engine:
inputs, outputs, bindings, stream = allocate_buffers(engine)
with engine.create_execution_context() as context:
np.copyto(inputs[0].host, data.ravel())
[output_trt] = do_inference(context, bindings=bindings, inputs=inputs,
outputs=outputs, stream=stream)
return output_trt
def main():
weights = [[[[0.000001, 0.000002, 0.000003],
[0.000004, 0.000005, 0.000006],
[7, 8, 9]]],
[[[9, 8, 7],
[6, 5, 4],
[30000, 20000, 10000]]]]
weights = np.array(weights)
data = [[[0.0001, 0.0002, 0.0003],
[0.0004, 0.0005, 0.0006],
[0.0007, 0.0008, 0.0009]]]
data = np.array(data)
print('=======Pytorch FP32=======')
output_pt = calc_pytorch(data, weights, use_fp16=False)
print('output_pt.dtype', output_pt.dtype)
print('output_pt {:.16f} {:.16f}'.format(output_pt[0], output_pt[1]))
print('=======Pytorch FP16=======')
output_pt = calc_pytorch(data, weights, use_fp16=True)
print('=======TensorRT FP32=======')
output_trt = calc_tensorrt(data, weights, use_fp16=False)
print('output_trt.dtype', output_trt.dtype)
print('output_trt {:.16f} {:.16f}'.format(output_trt[0], output_trt[1]))
print('=======TensorRT FP16=======')
output_trt = calc_tensorrt(data, weights, use_fp16=True)
if __name__ == '__main__':
print('TensorRT version:', trt.__version__)
main()
Result Tesla P100:
TensorRT version: 5.0.2.6
output_pt.dtype float32
output_pt 0.0194000080227852 46.0118980407714844
output_pt.dtype float16
output_pt 0.0193939208984375 46.0000000000000000
builder.platform_has_fast_fp16 True
builder.fp16_mode False
input_tensor.dtype DataType.FLOAT
conv_w.dtype DataType.FLOAT
conv_b.dtype DataType.FLOAT
output engine.get_binding_dtype(binding) DataType.FLOAT
output_trt.dtype float32
output_trt 0.0194000080227852 46.0118980407714844
builder.fp16_mode True
input_tensor.dtype DataType.HALF
conv_w.dtype DataType.HALF
conv_b.dtype DataType.HALF
output_trt 0.0193939208984375 46.0312500000000000
Result Jetson TX2:
TensorRT version: 5.0.6.3
output_pt 0.0194000061601400 46.0118942260742188
