Meet some problem with --precisionConstraints=obey --layerPrecisions
Description
convert an ONNX model which is very complex to an tensortrt fp32 model, the outputs of the onnx model and trtfp32 model are the same the commd as follows:
trtexec --onnx=encoder2.onnx --fp16 --saveEngine=encoderfp16.trt --useCudaGraph --verbose --tacticSources=-cublasLt,+cublas --workspace=10240M --minShapes=src_tokens:1x1000 --optShapes=src_tokens:1x100000 --maxShapes=src_tokens:1x700000 --preview=+fasterDynamicShapes0805 >log.en
all the thing is ok
However when I conert the onnx model to an tensort fp16 the output is very different and some weights affected
[01/13/2023-10:07:54] [W] [TRT] onnx2trt_utils.cpp:377: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[01/13/2023-10:09:43] [W] [TRT] Using kFASTER_DYNAMIC_SHAPES_0805 preview feature.
[01/13/2023-10:20:45] [W] [TRT] TensorRT encountered issues when converting weights between types and that could affect accuracy.
[01/13/2023-10:20:45] [W] [TRT] If this is not the desired behavior, please modify the weights or retrain with regularization to adjust the magnitude of the weights.
[01/13/2023-10:20:45] [W] [TRT] Check verbose logs for the list of affected weights.
[01/13/2023-10:20:45] [W] [TRT] - 254 weights are affected by this issue: Detected subnormal FP16 values.
[01/13/2023-10:20:45] [W] [TRT] - 31 weights are affected by this issue: Detected values less than smallest positive FP16 subnormal value and converted them to the FP16 minimum subnormalized value.
detail log in log.en
log.en (33.7 MB)
I want to use –precisionConstraints and --layerPrecisions to restrict some weiths to fp32,the commd as follows:
trtexec --onnx=encoder2.onnx --fp16 --saveEngine=encoderfp16.trt --useCudaGraph --verbose --tacticSources=-cublasLt,+cublas --workspace=10240M --minShapes=src_tokens:1x1000 --optShapes=src_tokens:1x100000 --maxShapes=src_tokens:1x700000 --preview=+fasterDynamicShapes0805 –precisionConstraints=obey --layerPrecisions=Conv_240.weight:fp32, Conv_263.weight:fp32, Conv_286.weight:fp32 >log.en1
But the log output are the same,
[01/13/2023-10:42:38] [W] [TRT] onnx2trt_utils.cpp:377: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[01/13/2023-10:44:28] [W] [TRT] Using kFASTER_DYNAMIC_SHAPES_0805 preview feature.
[01/13/2023-10:55:24] [W] [TRT] TensorRT encountered issues when converting weights between types and that could affect accuracy.
[01/13/2023-10:55:24] [W] [TRT] If this is not the desired behavior, please modify the weights or retrain with regularization to adjust the magnitude of the weights.
[01/13/2023-10:55:24] [W] [TRT] Check verbose logs for the list of affected weights.
[01/13/2023-10:55:24] [W] [TRT] - 254 weights are affected by this issue: Detected subnormal FP16 values.
[01/13/2023-10:55:24] [W] [TRT] - 31 weights are affected by this issue: Detected values less than smallest positive FP16 subnormal value and converted them to the FP16 minimum subnormalized value.
[01/13/2023-10:55:26] [W] [TRT] CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See CUDA_MODULE_LOADING in CUDA C++ Programming Guide
detail log in log.en1
log.en1 (33.9 MB)
A clear and concise description of the bug or issue.
Environment
TensorRT Version: TensorRT-8.5.2.2.Linux.x86_64-gnu.cuda-11.8.cudnn8.6.tar.gz
GPU Type: Tesla V100-PCIE
CUDA Version: 11.6
CUDNN Version: cudnn-linux-x86_64-8.6.0.163_cuda11-archive
PyTorch Version (if applicable): 1.12.0
onnx: 1.12.0
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
  • Exact steps/commands to build your repro
  • Exact steps/commands to run your repro
  • Full traceback of errors encountered
This issue looks same as the following. Please follow-up in the same post.
Thank you.
