How do I fine-tune the official Re-ID model?
• Hardware Platform (Jetson / GPU) GPU Ubuntu
• DeepStream Version 6.2
• TensorRT Version
• Issue Type( questions, new requirements, bugs) Question
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) Gst-nvtracker
My goal is to fine-tune the official Resnet 10 model trained on Mars dataset using KITTI Dataset. Is it possible to do it? Or use a completely new Re-ID model?
Can you share the link which the model you are using? Yes, you can use your own ReID model based on guide here: Gst-nvtracker — DeepStream documentation
But one of the answers said Deepstream supports custom onnx modules only from 6.3 onwards. I cannot update to that.
Seems you have similar topic here: Re-ID model engine failing in Deepstream 6.2 - #8 by kesong.
