How do I get color output from appsink with opencv?
For using appsink to get buffer in OpenCV, you have to suffer the extra emmcpy() from NVMM buffer to CPU buffers. A similar discussion is in
https://devtalk.nvidia.com/default/topic/1064944/
You may check if you ca apply your case to deepstream-app to achieve optimal performance.
