How does Jetson-nano enable the SPI bus, whether a driver is required, and what are the download instructions
Check below to use jetson-io to enable SPI
And after reboot have this command to load the driver. “sudo modprobe spidev”
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3271/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/hw_setup_jetson_io.html
No response
not 0x24
this ID register higher data not is 0x24,why
You can run the loopback test for confirm the SPI configuration first.
Should be able get relative topic by search in this forum.
is correct?this is spi.xfer() is correct?
Sorry, I don’t have experience for this device. You should check with the device spec.
