Hi:
I was doing some testing on CUDA, and I found an interesting thing regarding the thread scheduling… So, I have this “dummy” program that finds first prime factor for a given number
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include "conio.h"
#include "stdio.h"
#include "string.h"
#include "stdlib.h"
#include "time.h"
__global__ void addKernel(int* x, const int *n, const int o, int* r);
__global__ void addKernel(int* x, const int *n, const int o, int* r){
while (*r == 0) {
//THIS PRINTF ON PARTICULAR!
printf("Trying with: %i result: %i\n", x[blockIdx.x * blockDim.x + threadIdx.x], *n % x[blockIdx.x * blockDim.x + threadIdx.x]);
if (*n % x[blockIdx.x * blockDim.x + threadIdx.x] == 0 && x[blockIdx.x * blockDim.x + threadIdx.x] > 1) {
memcpy(r, &x[blockIdx.x * blockDim.x + threadIdx.x], sizeof(int));
x[blockIdx.x * blockDim.x + threadIdx.x] += o;
int main(int argc, char* argv[]) {
//kernel control
int cn;
int cm;
//aux data
int i;
if (argc > 1) {
cn = atoi(argv[1]);
cm = atoi(argv[2]);
} else {
cn = 4;
cm = 4;
//heap memory control
size_t maxMem;
//loop control
int ex = 0;
cudaError_t cuerr;
//measurement
float str;
float end;
float freq;
//HOST data
int* hx = (int*)malloc(sizeof(int) * cn * cm);
int* hr = (int*)malloc(sizeof(int));
int* hn = (int*)malloc(sizeof(int));
//DEVICE data
int* x;
int* r;
int* n;
cudaDeviceGetLimit(&maxMem, cudaLimitMallocHeapSize);
cudaDeviceSetLimit(cudaLimitMallocHeapSize, maxMem);
printf("Heap memory set result: %s\n", cudaGetErrorString(cudaGetLastError()));
printf("Kernel <<<%i, %i>>> will be launched\n", cn, cm);
//init DEVICE data
cudaMalloc(&x, sizeof(int) * cn * cm);
cudaMalloc(&r, sizeof(int));
cudaMalloc(&n, sizeof(int));
if (hx == NULL || hr == NULL || hn == NULL)
exit(-1);
//init HOST data
for (i = 0; i < cn * cm; i++)
hx[i] = i;
*hn = 131 * 313; //test data
*hr = 0;
//copy from HOST to DEVICE
cudaMemcpy(x, hx, sizeof(int) * cn * cm, cudaMemcpyHostToDevice);
cudaMemcpy(n, hn, sizeof(int), cudaMemcpyHostToDevice);
cudaMemcpy(r, hr, sizeof(int), cudaMemcpyHostToDevice);
printf("Calculation - Loop Start @%i\n", clock());
addKernel << <cn, cm >> > (x, n, (cn * cm), r);
cuerr = cudaDeviceSynchronize();
printf("Calculation - Loop Ends @%i\n", clock());
//copy r to HOST
cudaMemcpy(hr, r, sizeof(int), cudaMemcpyDeviceToHost);
printf("Result: %i\n", *hr);
return 0;
So, if I run it wtih first printf uncommented (the one that says “THIS PRINTF ON PARTICULAR”, the program ends quickly (as expected), and returns the lowest prime factor of the number
Trying with: 158 result: 81
Trying with: 159 result: 140
Calculation - Loop Ends @1245
Result: 131
On the other hand, if I comment that particular printf, program lasts considerably more and retrieves the highest primer factor of the number
Heap memory set result: no error
Kernel <<<4, 4>>> will be launched
Calculation - Loop Start @1107
Calculation - Loop Ends @48101
Result: 313
I don’t know why the behaviour changes so much… I even tried to use __shared__ data on the kernel, but similar result
__shared__ int sr;
sr = 0;
__syncthreads(); //ensure all threads have initial value of 0
while (sr == 0) {
//printf("Trying with: %i result: %i\n", x[blockIdx.x * blockDim.x + threadIdx.x], *n % x[blockIdx.x * blockDim.x + threadIdx.x]);
//memcpy(r, &x[blockIdx.x * blockDim.x + threadIdx.x], sizeof(int));
sr = x[blockIdx.x * blockDim.x + threadIdx.x];
__syncthreads(); //sync so every thread gets updated sr value
__syncthreads();
EDIT: after a few rounds of testing, I found that the way to make it work is by asking for block data specifically
__global__ void addKernel(int* x, const int n, const int o, int* r, const int cn){
if (blockIdx.x > 0) {
printf("Block %i activated...\n", blockIdx.x); //kind of "hack" to make it work"
while (*r == 0) {
if (n % x[blockIdx.x * blockDim.x + threadIdx.x] == 0 && x[blockIdx.x * blockDim.x + threadIdx.x] > 1) {
Is there maybe some compiler optimization that is changing some values when I remove the printf?
