how many simultaneous h264 encode sessions can run on Quadro M4000( 8 GB GDDR5) card?
Does anyone can help!!
how many simultaneous h264 encode sessions can run on Quadro K2200( 4 GB GDDR5) card?
how many simultaneous h264 encode sessions can run on GeForce GTX 960 card, and can it up to 2+ encode sessions?
I has A GeForce GTX960 card and use ffmpeg to do h264 encode, only 2 simultaneous h264 encode sessions can run!
I tested to run multi h264 encoding session on Quadro M2000.
it can run 17 number of h264 encoding session in 720p30fps 1Mbps.
it can run 7 number of h264 encoding session in 1080p30fps 1Mbps.
parameter is blow.
RC_2_PASS_QUALITY (rate control)
PRESET_LOW_LATENCY_HQ (preset)
NV12 (input format)
| NVIDIA-SMI 384.98 Driver Version: 384.98 |
| 0 Quadro M2000 Off | 00000000:02:00.0 Off | N/A |
| 69% 66C P0 42W / 75W | 2018MiB / 4036MiB | 37% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1274 C /usr/local/bin/0france3 107MiB |
| 0 4673 C /usr/local/bin/0TF1 108MiB |
| 0 4674 C /usr/local/bin/0France2 107MiB |
| 0 4676 C /usr/local/bin/0France4 95MiB |
| 0 4677 C /usr/local/bin/0M6 108MiB |
| 0 4678 C /usr/local/bin/0W9 108MiB |
| 0 4679 C /usr/local/bin/0Gulli 107MiB |
| 0 4680 C /usr/local/bin/ffmpeg 54MiB |
| 0 4681 C /usr/local/bin/ffmpeg 54MiB |
| 0 4682 C /usr/local/bin/0NRJ12 108MiB |
| 0 4683 C /usr/local/bin/ffmpeg 54MiB |
| 0 4684 C /usr/local/bin/ffmpeg 54MiB |
| 0 4685 C /usr/local/bin/ffmpeg 54MiB |
| 0 4686 C /usr/local/bin/0FRANCE5 108MiB |
| 0 4687 C /usr/local/bin/ffmpeg 54MiB |
| 0 4688 C /usr/local/bin/ffmpeg 54MiB |
| 0 4690 C /usr/local/bin/0CNEWS 107MiB |
| 0 4691 C /usr/local/bin/0CSTAR 108MiB |
| 0 4692 C /usr/local/bin/ffmpeg 108MiB |
| 0 4693 C /usr/local/bin/ffmpeg 108MiB |
| 0 4694 C /usr/local/bin/ffmpeg 108MiB |
| 0 4695 C /usr/local/bin/ffmpeg 108MiB |
