I’m going through the morpheus developer guide to learn how to use the Python API to create a pipeline.
I’ve created a basic pipeline, but i can’t run it in the developer container.
I built the container using Morpheus/docker/build_container_dev.sh at branch-25.06 · nv-morpheus/Morpheus · GitHub
Then use this cmd to run it on a nvidia brev gpu instance
docker run --rm -it --runtime=nvidia --gpus=all
–net=host
-v /var/run/docker.sock:/var/run/docker.sock
-v $(pwd):/workspace
-v /ephemeral:/ephemeral
–entrypoint /bin/bash
morpheus:dev-250521-amd64
Inside the container the morpheus python package isn’t available.
python -c “from morpheus.pipeline import LinearPipeline; print(‘✅ Morpheus Python SDK is working’)”
File “”, line 1, in
ModuleNotFoundError: No module named ‘morpheus.pipeline’
File “”, line 1, in
File “/workspace/Morpheus/python/morpheus/morpheus/pipeline/init.py”, line 36, in
from morpheus.pipeline.preallocator_mixin import PreallocatorMixin
File “/workspace/Morpheus/python/morpheus/morpheus/pipeline/preallocator_mixin.py”, line 25, in
from morpheus.common import TypeId
File “/workspace/Morpheus/python/morpheus/morpheus/common/init.py”, line 18, in
from morpheus._lib.common import FiberQueue
I’ve tried installing Morpheus/python/morpheus at branch-25.06 · nv-morpheus/Morpheus · GitHub with pip install -e .
Is there any documentation for setting up the environment so I can run pipelines using the Python API?
i’m using git branch-25.06
