I’m creating a docker container for to run the python samples in deepstream_python_apps
As far as I can see, the docker conatiners here (https://ngc.nvidia.com/catalog/containers/nvidia:deepstream) do not have python support. So I’m trying to add that to the docker file.
This is my dockerfile:
FROM nvcr.io/nvidia/deepstream:5.0-dp-20.04-devel
COPY myapp /root/apps/myapp
RUN apt-get update &&
apt-get upgrade -y
RUN apt-get install -y --force-yes git build-essential autotools-dev automake autoconf
libtool python3-dev libpython3-dev libgstreamer1.0-dev
INSTALL GST PYTHON
RUN apt-get install python-gi-dev -y &&
export GST_LIBS="-lgstreamer-1.0 -lgobject-2.0 -lglib-2.0" &&
export GST_CFLAGS="-pthread -I/usr/include/gstreamer-1.0 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include" &&
git clone https://github.com/GStreamer/gst-python.git &&
cd gst-python &&
git checkout 1a8f48a &&
./autogen.sh PYTHON=python3 &&
./configure PYTHON=python3 &&
make &&
make install
RUN cd /opt/nvidia/deepstream/deepstream-5.0/sources && git clone https://github.com/NVIDIA-AI-IOT/deepstream_python_apps
ENV NVIDIA_DRIVER_CAPABILITIES $NVIDIA_DRIVER_CAPABILITIES,video
When I try to run the python samples I get:
python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.h264
File “deepstream_test_1.py”, line 33, in
import pyds
ModuleNotFoundError: No module named ‘pyds’
Then when trying to setup the pyds module
cd /opt/nvidia/deepstream/deepstream/lib
python3 setup.py install
There is no setup file in the directory and no pyds.so file
What am I doing wrong?
How can I get this working?
