If I have a .c main file and a .f90 subroutine, e.g.
main.c
void testfunc();
int main(void)
testfunc();
testfunc.f90
subroutine testfunc() bind (C, name = "testfunc")
write(*,*) "Hello World!"
end subroutine
I normally compile these with the GNU compiler like so
gfortran -o my_prog main.c testfunc.f90
However, when I try this with pgfortran, I get the following errors
main.obj : error LNK2005: main already defined in f90main.obj
f90main.obj : error LNK2019: unresolved external symbol MAIN_ referenced in function main
Is there a standard procedure for compiling and linking C and Fortran code together on Windows?
If you want to call a fortran function from C, you’ll need to first create the object file (with -c) from the Fortran source. Then, invoke pgcc and pass in the created object file to link to. You’ll also want to add -pgf90libs to link to the runtime libraries.
$ cat Test.c
void testfunc();
int main ()
testfunc();
return 0;
$ cat TestMod.f90
module example
contains
subroutine testfunc() bind(c, name="testfunc")
end subroutine testfunc
end module example
$ pgfortran -c TestMod.f90
$ pgcc -o Test Test.c TestMod.obj -pgf90libs
Test.c:
$ ./Test.exe
Hello World!
