Visual Studio C & Fortran compiling - unresolved extern
I am building a Visual Studio 2010 solution with a Fortran90 project and a C project. I’m using pgf90 and the MSFT C/C++ compiler. The main routine is in C, so per instructions from the web I’ve compiled a static library for all the Fortran routines with the F90 project, and then I made the C project dependent on the static library project.
When the C project builds, I get unresolved references associated with the Fortran routines in the static lib. For example:
2>TestPVFLIBProjec.lib(igtran.obj) : error LNK2019: unresolved external symbol pgf90_alloc03 referenced in function igtran_
2>TestPVFLIBProjec.lib(init_par.obj) : error LNK2001: unresolved external symbol pgf90_alloc03
2>TestPVFLIBProjec.lib(pstep.obj) : error LNK2001: unresolved external symbol pgf90_alloc03
Note that I build things fine on the command line by doing the final link with pgf90. Here I’m using the MSFT C/C++ compiler to link the final solution.
What do I need to include to make this work? Thanks ahead. -Jeff
Hi Jeff,
You need to add the PGI runtime libraries to your link. (Note that I’m assuming that you are linking statically.)
From your VC++ project properties:
Add the PGI library directory, “C:\Program Files\PGI\win64\11.1\lib” to: “Linker | General | Additional Libraries Directories” (Adjust the PATH as necessary)
Then add the PGI Runtime libraries to “Linker | Input | Additional Dependencies”
Here’s the full list:
libpgmp.lib;pg.lib;libpgf90.lib;libpgf90_rpm1.lib;libpgf902.lib;libpgf90rtl.lib;libpgftnrtl.lib;libpgc.lib;libnspgc.lib;libcmt.lib;
Finally add “-nodefaultlib:msvcrtd” to “Linker | Command Line | Additional Options”. Note, change “msvcrtd” to “msvcrt” when changing from Debug to a Release build.
Hope this helps,
Mat
That did it. Thanks, Mat!
