Hi all,
Let me preface by saying I’m not a Fortran guy. This is my first time even using PGI. I have some code that was developed by someone else and I’m trying to integrate it into a MFC C++ application. I’ve created a static library (compiled with pgf90) but I’m having an issue with linkage. I finally managed to track down almost all the libraries I was missing, but now I seem to be left with the following errors (VS2008):
error LNK2019: unresolved external symbol __environ referenced in function _pgf90_compiled
error LNK2001: unresolved external symbol __environ
I found only one similar problem on the forums here: https://forums.developer.nvidia.com/t/pvf-2010-linking-c-and-fortran/132315/1
Much like the OP in that posting, I originally had a name mangling problem. I was able to correct that both using the -Miface=unix and by fixing it from the calling code. Like him, I also hit a lot of unresolved externals that were mostly cleaned up by linking in libpgsse1 and libpgsse2. I don’t really understand how to fix this issue, though.
Any help would be greatly appreciated.
