How switch camera output - Gst-nvmultistreamtiler
I have multiples RTSP input.
I’m trying to switch between different channels showing one channel at a time.
The below parameter change it only as initial setup
tiler.set_property("show-source", 1)
Is there any DEEPSTREAM PYTHON API to change the show-source at runtime?
You can try to add nvvideoconvert plugin to rotate the picture.
sry I mean switch between different channels. (rotate)
I managed to do it. Just program the switch in the function.
tiler_sink_pad.add_probe(Gst.PadProbeType.BUFFER, tiler_sink_pad_buffer_probe, 0)
tiler.set_property("show-source", <stream_id>) `
