How Tensorrt's horizontal layer fusion output data works?
Description
When i build a tensorrt engine from inceptionResnetv2 onnx model in int8 precision;There is so called horizontal layer fusion in convolutions with same input tensor and weight kernel size;(The red rectangles below)
It seems that fused convolution output as [64, 208, 35, 35], and deliver to the next convolutions directly; So these convolutions’ input channels were changed to 208 ? or there is data offset in the convolution input data?
Environment
TensorRT Version: 8.2
GPU Type: A10
CUDA Version: 11.2
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
  1. validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
