I recommend P2000 (but check support issues like passthrough in virtualization environment (see https://devtalk.nvidia.com/default/topic/992447)). The Pascal generation (P2000) has also HEVC encoder (not supported by Maxwell Gen 1 (K2200)) (see https://developer.nvidia.com/video-encode-decode-gpu-support-matrix). P2000 has also more RAM (5GB vs. 4GB) (see memory allocation problems with multiple encoder streams https://gridforums.nvidia.com/default/topic/1310/#4789).
My K2200 has max core clock 1124 Mhz (reported by nvidia-smi) and my P2000 has max core clock 1721 (reported by nvidia-smi (after “nvidia-smi -ac 3504,1721”)) and if you read “NVENC_Application_Note.pdf” you get expected performance metrics (but reality depends on many factors):
Hi mcerveny,
What tool did you use to verify the results from Nvidia (number of encoded frames)
I want to use it to benchmark M4000 and compare with P4000 with non 16/9 ratio streams.
Thanks in advance,
