Originally published at: https://developer.nvidia.com/blog/how-access-global-memory-efficiently-cuda-c-kernels/
In the previous two posts we looked at how to move data efficiently between the host and device. In this sixth post of our CUDA C/C++ series we discuss how to efficiently access device memory, in particular global memory, from within kernels. There are several kinds of memory on a CUDA device, each with different…
In your description, you discussed that "Arrays allocated in device memory are aligned to 256-byte memory segments by the CUDA driver." Why are the arrays allocated in memory aligned to 256-byte memory segments? Is it limited by the CUDA Driver? Are there other alignments?
Minor mistake:
The post is tagged as "CUDA C++" while the rest of the post are refered as "CUDA C/C++"
Fixed. Thanks!
Hi Mark,
Could you explain this statement?
"For the C870 or any other device with a compute capability of 1.0, any misaligned access by a half warp of threads (or aligned access where the threads of the half warp do not access memory in sequence) results in 16 separate 32-byte transactions."
And then why were there 4 bytes requested per 32-byte transaction?
Thank you!
if i'm not mistaken, then :
* 4 bytes are requested per 32-byte transaction because the testes presented are for single precision, so elements are coded by 4 bytes
* in the C870, if accesses are not aligned, then each access causes a NEW TRANSACTION, and i suppose that the hardware choses -- from 32,64,128 byte available transactions -- the smallest transaction in term of bytes fetched to satisfy the requested element (in this case 4 bytes, so 32 is more than enough)
Are all those observation and best practices explained in the post still valid today, 5 years after the original post? Does this article equally applies to the newer cards with, say, compute capability 6.0?
https://docs.nvidia.com/cud... has information about compute capability of 6.0 and above.
