I have been trying out the global memory coalescing code from this blog.
https://devblogs.nvidia.com/how-access-global-memory-efficiently-cuda-c-kernels/
The code is as follows.
/* Copyright (c) 1993-2015, NVIDIA CORPORATION. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of NVIDIA CORPORATION nor the names of its
* contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
* EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
* PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <assert.h>
// Convenience function for checking CUDA runtime API results
// can be wrapped around any runtime API call. No-op in release builds.
inline
cudaError_t checkCuda(cudaError_t result)
#if defined(DEBUG) || defined(_DEBUG)
if (result != cudaSuccess) {
fprintf(stderr, "CUDA Runtime Error: %s\n", cudaGetErrorString(result));
assert(result == cudaSuccess);
#endif
return result;
template <typename T>
__global__ void offset(T* a, int s)
int i = blockDim.x * blockIdx.x + threadIdx.x + s;
a[i] = a[i] + 1;
__global__ void stride(T* a, int s)
int i = (blockDim.x * blockIdx.x + threadIdx.x) * s;
a[i] = a[i] + 1;
void runTest(int deviceId, int nMB)
int blockSize = 256;
float ms;
T *d_a;
cudaEvent_t startEvent, stopEvent;
int n = nMB*1024*1024/sizeof(T);
// NB: d_a(33*nMB) for stride case
checkCuda( cudaMalloc(&d_a, n * 33 * sizeof(T)) );
checkCuda( cudaEventCreate(&startEvent) );
checkCuda( cudaEventCreate(&stopEvent) );
printf("Offset, Bandwidth (GB/s):\n");
offset<<<n/blockSize, blockSize>>>(d_a, 0); // warm up
for (int i = 0; i <= 32; i++) {
checkCuda( cudaMemset(d_a, 0, n * sizeof(T)) );
checkCuda( cudaEventRecord(startEvent,0) );
offset<<<n/blockSize, blockSize>>>(d_a, i);
checkCuda( cudaEventRecord(stopEvent,0) );
checkCuda( cudaEventSynchronize(stopEvent) );
checkCuda( cudaEventElapsedTime(&ms, startEvent, stopEvent) );
printf("%d, %f\n", i, 2*nMB/ms);
printf("\n");
printf("Stride, Bandwidth (GB/s):\n");
stride<<<n/blockSize, blockSize>>>(d_a, 1); // warm up
for (int i = 1; i <= 32; i++) {
stride<<<n/blockSize, blockSize>>>(d_a, i);
checkCuda( cudaEventDestroy(startEvent) );
checkCuda( cudaEventDestroy(stopEvent) );
cudaFree(d_a);
int main(int argc, char **argv)
int nMB = 4;
int deviceId = 0;
bool bFp64 = false;
for (int i = 1; i < argc; i++) {
if (!strncmp(argv[i], "dev=", 4))
deviceId = atoi((char*)(&argv[i][4]));
else if (!strcmp(argv[i], "fp64"))
bFp64 = true;
cudaDeviceProp prop;
checkCuda( cudaSetDevice(deviceId) )
checkCuda( cudaGetDeviceProperties(&prop, deviceId) );
printf("Device: %s\n", prop.name);
printf("Transfer size (MB): %d\n", nMB);
printf("%s Precision\n", bFp64 ? "Double" : "Single");
if (bFp64) runTest<double>(deviceId, nMB);
else runTest<float>(deviceId, nMB);
I ran my tests on a GTX 850M card with compute capability 5.0. When I ran with the default setting, where nMB = 4, the “offset” bandwidths were all around 25 GB/s and the “stride” bandwidth for stride = 1 was also around 25 GB/s, and the effect of non-coalesced access was very clear as the bandwidth soon deteriorated as the stride becomes larger. Everything seemed normal.
However, when I set nMB = 100, the bandwidths skyrocketed to 80000+ GB/s, and increasing the stride seemed to have very little impact on the bandwidth. Setting nMB to be even larger resulted in even larger bandwidths and similar impact of non-coalesced access. I wonder why this happened? Thank you!
