I want to add 4 new parameters to the deepstream_app_config_yoloV2_tiny.txt file under [ds-example] as follows (line 7 - 10) .
[ds-example]
enable=1
processing-width=1280
processing-height=720
full-frame=1
unique-id=15
x-coordinate-top=642
y-coordinate-top=10
x-coordinate-bottom=618
y-coordinate-bottom=720
And I want to access those values inside gstdsexample.cpp file gst_dsexample_transform_ip() function. I have customized the file as follows.
* Copyright (c) 2017-2019, NVIDIA CORPORATION. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
#include <string.h>
#include <string>
#include <sstream>
#include <iostream>
#include <ostream>
#include <fstream>
#include "gstdsexample.h"
#include <npp.h>
#include <sys/time.h>
#include <typeindex>
#include <typeinfo>
GST_DEBUG_CATEGORY_STATIC (gst_dsexample_debug);
#define GST_CAT_DEFAULT gst_dsexample_debug
#define USE_EGLIMAGE 1
static GQuark _dsmeta_quark = 0;
/* Enum to identify properties */
enum
PROP_0,
PROP_UNIQUE_ID,
PROP_PROCESSING_WIDTH,
PROP_PROCESSING_HEIGHT,
PROP_PROCESS_FULL_FRAME,
PROP_GPU_DEVICE_ID,
PROP_PROCESSING_TOPX,
PROP_PROCESSING_TOPY,
PROP_PROCESSING_BOTTOMX,
PROP_PROCESSING_BOTTOMY
#define CHECK_NVDS_MEMORY_AND_GPUID(object, surface) \
({ int _errtype=0;\
do { \
if ((surface->memType == NVBUF_MEM_DEFAULT || surface->memType == NVBUF_MEM_CUDA_DEVICE) && \
(surface->gpuId != object->gpu_id)) { \
GST_ELEMENT_ERROR (object, RESOURCE, FAILED, \
("Input surface gpu-id doesnt match with configured gpu-id for element," \
" please allocate input using unified memory, or use same gpu-ids"),\
("surface-gpu-id=%d,%s-gpu-id=%d",surface->gpuId,GST_ELEMENT_NAME(object),\
object->gpu_id)); \
_errtype = 1;\
} while(0); \
_errtype; \
/* Default values for properties */
#define DEFAULT_UNIQUE_ID 15
#define DEFAULT_PROCESSING_WIDTH 660
#define DEFAULT_PROCESSING_HEIGHT 480
#define DEFAULT_PROCESS_FULL_FRAME TRUE
#define DEFAULT_GPU_ID 0
#define DEFAULT_PROCESSING_TOPX 640
#define DEFAULT_PROCESSING_TOPY 1
#define DEFAULT_PROCESSING_BOTTOMX 640
#define DEFAULT_PROCESSING_BOTTOMY 720
#define RGB_BYTES_PER_PIXEL 3
#define RGBA_BYTES_PER_PIXEL 4
#define Y_BYTES_PER_PIXEL 1
#define UV_BYTES_PER_PIXEL 2
#define MIN_INPUT_OBJECT_WIDTH 16
#define MIN_INPUT_OBJECT_HEIGHT 16
#define CHECK_NPP_STATUS(npp_status,error_str) do { \
if ((npp_status) != NPP_SUCCESS) { \
g_print ("Error: %s in %s at line %d: NPP Error %d\n", \
error_str, __FILE__, __LINE__, npp_status); \
goto error; \
} while (0)
#define CHECK_CUDA_STATUS(cuda_status,error_str) do { \
if ((cuda_status) != cudaSuccess) { \
g_print ("Error: %s in %s at line %d (%s)\n", \
error_str, __FILE__, __LINE__, cudaGetErrorName(cuda_status)); \
goto error; \
} while (0)
/* By default NVIDIA Hardware allocated memory flows through the pipeline. We
* will be processing on this type of memory only. */
#define GST_CAPS_FEATURE_MEMORY_NVMM "memory:NVMM"
static GstStaticPadTemplate gst_dsexample_sink_template =
GST_STATIC_PAD_TEMPLATE ("sink",
GST_PAD_SINK,
GST_PAD_ALWAYS,
GST_STATIC_CAPS (GST_VIDEO_CAPS_MAKE_WITH_FEATURES
(GST_CAPS_FEATURE_MEMORY_NVMM,
"{ NV12, RGBA, I420 }")));
static GstStaticPadTemplate gst_dsexample_src_template =
GST_STATIC_PAD_TEMPLATE ("src",
GST_PAD_SRC,
GST_PAD_ALWAYS,
/* Define our element type. Standard GObject/GStreamer boilerplate stuff */
#define gst_dsexample_parent_class parent_class
G_DEFINE_TYPE (GstDsExample, gst_dsexample, GST_TYPE_BASE_TRANSFORM);
static void gst_dsexample_set_property (GObject * object, guint prop_id,
const GValue * value, GParamSpec * pspec);
static void gst_dsexample_get_property (GObject * object, guint prop_id,
static gboolean gst_dsexample_set_caps (GstBaseTransform * btrans,
GstCaps * incaps, GstCaps * outcaps);
static gboolean gst_dsexample_start (GstBaseTransform * btrans);
static gboolean gst_dsexample_stop (GstBaseTransform * btrans);
static GstFlowReturn gst_dsexample_transform_ip (GstBaseTransform *
btrans, GstBuffer * inbuf);
static void
attach_metadata_full_frame (GstDsExample * dsexample, NvDsFrameMeta *frame_meta,
gdouble scale_ratio, DsExampleOutput * output, guint batch_id);
static void attach_metadata_object (GstDsExample * dsexample,
NvDsObjectMeta * obj_meta, DsExampleOutput * output);
/* Install properties, set sink and src pad capabilities, override the required
* functions of the base class, These are common to all instances of the
* element.
static void
gst_dsexample_class_init (GstDsExampleClass * klass)
GObjectClass *gobject_class;
GstElementClass *gstelement_class;
GstBaseTransformClass *gstbasetransform_class;
// Indicates we want to use DS buf api
g_setenv ("DS_NEW_BUFAPI", "1", TRUE);
gobject_class = (GObjectClass *) klass;
gstelement_class = (GstElementClass *) klass;
gstbasetransform_class = (GstBaseTransformClass *) klass;
/* Overide base class functions */
gobject_class->set_property = GST_DEBUG_FUNCPTR (gst_dsexample_set_property);
gobject_class->get_property = GST_DEBUG_FUNCPTR (gst_dsexample_get_property);
gstbasetransform_class->set_caps = GST_DEBUG_FUNCPTR (gst_dsexample_set_caps);
gstbasetransform_class->start = GST_DEBUG_FUNCPTR (gst_dsexample_start);
gstbasetransform_class->stop = GST_DEBUG_FUNCPTR (gst_dsexample_stop);
gstbasetransform_class->transform_ip =
GST_DEBUG_FUNCPTR (gst_dsexample_transform_ip);
/* Install properties */
g_object_class_install_property (gobject_class, PROP_UNIQUE_ID,
g_param_spec_uint ("unique-id",
"Unique ID",
"Unique ID for the element. Can be used to identify output of the"
" element", 0, G_MAXUINT, DEFAULT_UNIQUE_ID, (GParamFlags)
(G_PARAM_READWRITE | G_PARAM_STATIC_STRINGS)));
g_object_class_install_property (gobject_class, PROP_PROCESSING_WIDTH,
g_param_spec_int ("processing-width",
"Processing Width",
"Width of the input buffer to algorithm",
1, G_MAXINT, DEFAULT_PROCESSING_WIDTH, (GParamFlags)
g_object_class_install_property (gobject_class, PROP_PROCESSING_HEIGHT,
g_param_spec_int ("processing-height",
"Processing Height",
"Height of the input buffer to algorithm",
1, G_MAXINT, DEFAULT_PROCESSING_HEIGHT, (GParamFlags)
g_object_class_install_property (gobject_class, PROP_PROCESS_FULL_FRAME,
g_param_spec_boolean ("full-frame",
"Full frame",
"Enable to process full frame or disable to process objects detected"
"by primary detector", DEFAULT_PROCESS_FULL_FRAME, (GParamFlags)
g_object_class_install_property (gobject_class, PROP_GPU_DEVICE_ID,
g_param_spec_uint ("gpu-id",
"Set GPU Device ID",
"Set GPU Device ID", 0,
G_MAXUINT, 0,
GParamFlags
G_PARAM_STATIC_STRINGS | GST_PARAM_MUTABLE_READY)));
g_object_class_install_property (gobject_class, PROP_PROCESSING_TOPX,
g_param_spec_int ("x-coordinate-top",
"X Coordinate Top",
"X coordinate of the top of the line",
1, G_MAXINT, DEFAULT_PROCESSING_TOPX, (GParamFlags)
g_object_class_install_property (gobject_class, PROP_PROCESSING_TOPY,
g_param_spec_int ("y-coordinate-top",
"Y Coordinate Top",
"Y coordinate of the top of the line",
1, G_MAXINT, DEFAULT_PROCESSING_TOPY, (GParamFlags)
g_object_class_install_property (gobject_class, PROP_PROCESSING_BOTTOMX,
g_param_spec_int ("x-coordinate-bottom",
"X Coordinate Bottom",
"X coordinate of the bottom of the line",
1, G_MAXINT, DEFAULT_PROCESSING_BOTTOMX, (GParamFlags)
g_object_class_install_property (gobject_class, PROP_PROCESSING_BOTTOMY,
g_param_spec_int ("y-coordinate-bottom",
"Y Coordinate Bottom",
"Y coordinate of the bottom of the line",
1, G_MAXINT, DEFAULT_PROCESSING_BOTTOMY, (GParamFlags)
/* Set sink and src pad capabilities */
gst_element_class_add_pad_template (gstelement_class,
gst_static_pad_template_get (&gst_dsexample_src_template));
gst_static_pad_template_get (&gst_dsexample_sink_template));
/* Set metadata describing the element */
gst_element_class_set_details_simple (gstelement_class,
"DsExample plugin",
"DsExample Plugin",
"Process a 3rdparty example algorithm on objects / full frame",
"NVIDIA Corporation. Post on Deepstream for Tesla forum for any queries "
"@ https://devtalk.nvidia.com/default/board/209/");
static void
gst_dsexample_init (GstDsExample * dsexample)
GstBaseTransform *btrans = GST_BASE_TRANSFORM (dsexample);
/* We will not be generating a new buffer. Just adding / updating
* metadata. */
gst_base_transform_set_in_place (GST_BASE_TRANSFORM (btrans), TRUE);
/* We do not want to change the input caps. Set to passthrough. transform_ip
* is still called. */
gst_base_transform_set_passthrough (GST_BASE_TRANSFORM (btrans), TRUE);
/* Initialize all property variables to default values */
dsexample->unique_id = DEFAULT_UNIQUE_ID;
dsexample->processing_width = DEFAULT_PROCESSING_WIDTH;
dsexample->processing_height = DEFAULT_PROCESSING_HEIGHT;
dsexample->process_full_frame = DEFAULT_PROCESS_FULL_FRAME;
dsexample->gpu_id = DEFAULT_GPU_ID;
dsexample->x_coordinate_top = DEFAULT_PROCESSING_TOPX;
dsexample->y_coordinate_top = DEFAULT_PROCESSING_TOPY;
dsexample->x_coordinate_bottom = DEFAULT_PROCESSING_BOTTOMX;
dsexample->y_coordinate_bottom = DEFAULT_PROCESSING_BOTTOMY;
/* This quark is required to identify NvDsMeta when iterating through
* the buffer metadatas */
if (!_dsmeta_quark)
_dsmeta_quark = g_quark_from_static_string (NVDS_META_STRING);
/* Function called when a property of the element is set. Standard boilerplate.
static void
GstDsExample *dsexample = GST_DSEXAMPLE (object);
switch (prop_id) {
case PROP_UNIQUE_ID:
dsexample->unique_id = g_value_get_uint (value);
break;
case PROP_PROCESSING_WIDTH:
dsexample->processing_width = g_value_get_int (value);
break;
case PROP_PROCESSING_HEIGHT:
dsexample->processing_height = g_value_get_int (value);
break;
case PROP_PROCESS_FULL_FRAME:
dsexample->process_full_frame = g_value_get_boolean (value);
break;
case PROP_GPU_DEVICE_ID:
dsexample->gpu_id = g_value_get_uint (value);
break;
case PROP_PROCESSING_TOPX:
dsexample->x_coordinate_top = g_value_get_int (value);
break;
case PROP_PROCESSING_TOPY:
dsexample->y_coordinate_top = g_value_get_int (value);
break;
case PROP_PROCESSING_BOTTOMX:
dsexample->x_coordinate_bottom = g_value_get_int (value);
break;
case PROP_PROCESSING_BOTTOMY:
dsexample->y_coordinate_bottom = g_value_get_int (value);
break;
default:
G_OBJECT_WARN_INVALID_PROPERTY_ID (object, prop_id, pspec);
break;
/* Function called when a property of the element is requested. Standard
* boilerplate.
static void
switch (prop_id) {
g_value_set_uint (value, dsexample->unique_id);
break;
g_value_set_int (value, dsexample->processing_width);
break;
g_value_set_int (value, dsexample->processing_height);
break;
g_value_set_boolean (value, dsexample->process_full_frame);
break;
g_value_set_uint (value, dsexample->gpu_id);
break;
g_value_set_int (value, dsexample->x_coordinate_top);
break;
g_value_set_int (value, dsexample->y_coordinate_top);
break;
g_value_set_int (value, dsexample->x_coordinate_bottom);
break;
g_value_set_int (value, dsexample->y_coordinate_bottom);
break;
default:
break;
* Initialize all resources and start the output thread
static gboolean
GstDsExample *dsexample = GST_DSEXAMPLE (btrans);
NvBufSurfaceCreateParams create_params;
DsExampleInitParams init_params =
{ dsexample->processing_width, dsexample->processing_height,
GstQuery *queryparams = NULL;
guint batch_size = 1;
/* Algorithm specific initializations and resource allocation. */
dsexample->dsexamplelib_ctx = DsExampleCtxInit (&init_params);
GST_DEBUG_OBJECT (dsexample, "ctx lib %p \n", dsexample->dsexamplelib_ctx);
CHECK_CUDA_STATUS (cudaSetDevice (dsexample->gpu_id),
"Unable to set cuda device");
dsexample->batch_size = 1;
queryparams = gst_nvquery_batch_size_new ();
if (gst_pad_peer_query (GST_BASE_TRANSFORM_SINK_PAD (btrans), queryparams)
|| gst_pad_peer_query (GST_BASE_TRANSFORM_SRC_PAD (btrans), queryparams)) {
if (gst_nvquery_batch_size_parse (queryparams, &batch_size)) {
dsexample->batch_size = batch_size;
GST_DEBUG_OBJECT (dsexample, "Setting batch-size %d \n",
dsexample->batch_size);
gst_query_unref (queryparams);
CHECK_CUDA_STATUS (cudaStreamCreate (&dsexample->cuda_stream),
"Could not create cuda stream");
if (dsexample->inter_buf)
NvBufSurfaceDestroy (dsexample->inter_buf);
dsexample->inter_buf = NULL;
/* An intermediate buffer for NV12/RGBA to BGR conversion will be
* required. Can be skipped if custom algorithm can work directly on NV12/RGBA. */
create_params.gpuId = dsexample->gpu_id;
create_params.width = dsexample->processing_width;
create_params.height = dsexample->processing_height;
create_params.size = 0;
create_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
create_params.layout = NVBUF_LAYOUT_PITCH;
#ifdef __aarch64__
create_params.memType = NVBUF_MEM_DEFAULT;
#else
create_params.memType = NVBUF_MEM_CUDA_UNIFIED;
#endif
if (NvBufSurfaceCreate (&dsexample->inter_buf, 1,
&create_params) != 0) {
GST_ERROR ("Error: Could not allocate internal buffer for dsexample");
goto error;
// Create host memory for storing converted/scaled interleaved RGB data
CHECK_CUDA_STATUS (cudaMallocHost (&dsexample->host_rgb_buf,
dsexample->processing_width * dsexample->processing_height *
RGB_BYTES_PER_PIXEL), "Could not allocate cuda host buffer");
GST_DEBUG_OBJECT (dsexample, "allocated cuda buffer %p \n",
dsexample->host_rgb_buf);
// CV Mat containing interleaved RGB data. This call does not allocate memory.
// It uses host_rgb_buf as data.
dsexample->cvmat =
new cv::Mat (dsexample->processing_height, dsexample->processing_width,
CV_8UC3, dsexample->host_rgb_buf,
dsexample->processing_width * RGB_BYTES_PER_PIXEL);
if (!dsexample->cvmat)
goto error;
GST_DEBUG_OBJECT (dsexample, "created CV Mat\n");
return TRUE;
error:
if (dsexample->host_rgb_buf) {
cudaFreeHost (dsexample->host_rgb_buf);
dsexample->host_rgb_buf = NULL;
if (dsexample->cuda_stream) {
cudaStreamDestroy (dsexample->cuda_stream);
dsexample->cuda_stream = NULL;
if (dsexample->dsexamplelib_ctx)
DsExampleCtxDeinit (dsexample->dsexamplelib_ctx);
return FALSE;
* Stop the output thread and free up all the resources
static gboolean
NvBufSurfaceDestroy(dsexample->inter_buf);
delete dsexample->cvmat;
dsexample->cvmat = NULL;
GST_DEBUG_OBJECT (dsexample, "deleted CV Mat \n");
// Deinit the algorithm library
dsexample->dsexamplelib_ctx = NULL;
GST_DEBUG_OBJECT (dsexample, "ctx lib released \n");
return TRUE;
* Called when source / sink pad capabilities have been negotiated.
static gboolean
gst_dsexample_set_caps (GstBaseTransform * btrans, GstCaps * incaps,
GstCaps * outcaps)
/* Save the input video information, since this will be required later. */
gst_video_info_from_caps (&dsexample->video_info, incaps);
return TRUE;
error:
return FALSE;
* Scale the entire frame to the processing resolution maintaining aspect ratio.
* Or crop and scale objects to the processing resolution maintaining the aspect
* ratio. Remove the padding required by hardware and convert from RGBA to RGB
* using openCV. These steps can be skipped if the algorithm can work with
* padded data and/or can work with RGBA.
get_converted_mat (GstDsExample * dsexample, NvBufSurface *input_buf, gint idx,
NvOSD_RectParams * crop_rect_params, gdouble & ratio, gint input_width,
gint input_height)
NvBufSurfTransform_Error err;
NvBufSurfTransformConfigParams transform_config_params;
NvBufSurfTransformParams transform_params;
NvBufSurfTransformRect src_rect;
NvBufSurfTransformRect dst_rect;
NvBufSurface ip_surf;
cv::Mat in_mat;
ip_surf = *input_buf;
ip_surf.numFilled = ip_surf.batchSize = 1;
ip_surf.surfaceList = &(input_buf->surfaceList[idx]);
gint src_left = GST_ROUND_UP_2(crop_rect_params->left);
gint src_top = GST_ROUND_UP_2(crop_rect_params->top);
gint src_width = GST_ROUND_DOWN_2(crop_rect_params->width);
gint src_height = GST_ROUND_DOWN_2(crop_rect_params->height);
// Maintain aspect ratio
double hdest = dsexample->processing_width * src_height / (double) src_width;
double wdest = dsexample->processing_height * src_width / (double) src_height;
guint dest_width, dest_height;
if (hdest <= dsexample->processing_height) {
dest_width = dsexample->processing_width;
dest_height = hdest;
} else {
dest_width = wdest;
dest_height = dsexample->processing_height;
// Configure transform session parameters for the transformation
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
transform_config_params.gpu_id = dsexample->gpu_id;
transform_config_params.cuda_stream = dsexample->cuda_stream;
// Set the transform session parameters for the conversions executed in this
// thread.
err = NvBufSurfTransformSetSessionParams (&transform_config_params);
if (err != NvBufSurfTransformError_Success) {
GST_ELEMENT_ERROR (dsexample, STREAM, FAILED,
("NvBufSurfTransformSetSessionParams failed with error %d", err), (NULL));
goto error;
// Calculate scaling ratio while maintaining aspect ratio
ratio = MIN (1.0 * dest_width/ src_width, 1.0 * dest_height / src_height);
if ((crop_rect_params->width == 0) || (crop_rect_params->height == 0)) {
("%s:crop_rect_params dimensions are zero",__func__), (NULL));
goto error;
#ifdef __aarch64__
if (ratio <= 1.0 / 16 || ratio >= 16.0) {
// Currently cannot scale by ratio > 16 or < 1/16 for Jetson
goto error;
#endif
// Set the transform ROIs for source and destination
src_rect = {(guint)src_top, (guint)src_left, (guint)src_width, (guint)src_height};
dst_rect = {0, 0, (guint)dest_width, (guint)dest_height};
// Set the transform parameters
transform_params.src_rect = &src_rect;
transform_params.dst_rect = &dst_rect;
transform_params.transform_flag =
NVBUFSURF_TRANSFORM_FILTER | NVBUFSURF_TRANSFORM_CROP_SRC |
NVBUFSURF_TRANSFORM_CROP_DST;
transform_params.transform_filter = NvBufSurfTransformInter_Default;
//Memset the memory
NvBufSurfaceMemSet (dsexample->inter_buf, 0, 0, 0);
GST_DEBUG_OBJECT (dsexample, "Scaling and converting input buffer\n");
// Transformation scaling+format conversion if any.
err = NvBufSurfTransform (&ip_surf, dsexample->inter_buf, &transform_params);
("NvBufSurfTransform failed with error %d while converting buffer", err),
(NULL));
goto error;
// Map the buffer so that it can be accessed by CPU
if (NvBufSurfaceMap (dsexample->inter_buf, 0, 0, NVBUF_MAP_READ) != 0){
goto error;
// Cache the mapped data for CPU access
NvBufSurfaceSyncForCpu (dsexample->inter_buf, 0, 0);
// Use openCV to remove padding and convert RGBA to BGR. Can be skipped if
// algorithm can handle padded RGBA data.
in_mat =
CV_8UC4, dsexample->inter_buf->surfaceList[0].mappedAddr.addr[0],
dsexample->inter_buf->surfaceList[0].pitch);
cv::cvtColor (in_mat, *dsexample->cvmat, CV_RGBA2BGR);
if (NvBufSurfaceUnMap (dsexample->inter_buf, 0, 0)){
goto error;
#ifdef __aarch64__
// To use the converted buffer in CUDA, create an EGLImage and then use
// CUDA-EGL interop APIs
if (USE_EGLIMAGE) {
if (NvBufSurfaceMapEglImage (dsexample->inter_buf, 0) !=0 ) {
goto error;
// dsexample->inter_buf->surfaceList[0].mappedAddr.eglImage
// Use interop APIs cuGraphicsEGLRegisterImage and
// cuGraphicsResourceGetMappedEglFrame to access the buffer in CUDA
// Destroy the EGLImage
NvBufSurfaceUnMapEglImage (dsexample->inter_buf, 0);
#endif
/* We will first convert only the Region of Interest (the entire frame or the
* object bounding box) to RGB and then scale the converted RGB frame to
* processing resolution. */
return GST_FLOW_OK;
error:
return GST_FLOW_ERROR;
* Called when element recieves an input buffer from upstream element.
gst_dsexample_transform_ip (GstBaseTransform * btrans, GstBuffer * inbuf)
GstMapInfo in_map_info;
GstFlowReturn flow_ret = GST_FLOW_ERROR;
gdouble scale_ratio = 1.0;
DsExampleOutput *output;
NvBufSurface *surface = NULL;
NvDsBatchMeta *batch_meta = NULL;
NvDsFrameMeta *frame_meta = NULL;
NvDsMetaList * l_frame = NULL;
guint i = 0;
dsexample->frame_num++;
memset (&in_map_info, 0, sizeof (in_map_info));
if (!gst_buffer_map (inbuf, &in_map_info, GST_MAP_READ)) {
g_print ("Error: Failed to map gst buffer\n");
goto error;
surface = (NvBufSurface *) in_map_info.data;
"Processing Frame %" G_GUINT64_FORMAT " Surface %p\n",
dsexample->frame_num, surface);
if (CHECK_NVDS_MEMORY_AND_GPUID (dsexample, surface))
goto error;
batch_meta = gst_buffer_get_nvds_batch_meta (inbuf);
if (batch_meta == nullptr) {
("NvDsBatchMeta not found for input buffer."), (NULL));
if (dsexample->process_full_frame) {
// Using object crops as input to the algorithm. The objects are detected by
// the primary detector
NvDsMetaList * l_obj = NULL;
NvDsObjectMeta *obj_meta = NULL;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next)
frame_meta = (NvDsFrameMeta *) (l_frame->data);
NvOSD_RectParams rect_params;
// Scale the entire frame to processing resolution
rect_params.left = 0;
rect_params.top = 0;
rect_params.width = dsexample->video_info.width;
rect_params.height = dsexample->video_info.height;
// Scale and convert the frame
if (get_converted_mat (dsexample, surface, i, &rect_params,
scale_ratio, dsexample->video_info.width,
dsexample->video_info.height) != GST_FLOW_OK) {
goto error;
// Process to get the output
output =
DsExampleProcess (dsexample->dsexamplelib_ctx,
dsexample->cvmat->data);
// Attach the metadata for the full frame
//std::cout << "Full frame\n" << frame_meta << std::endl;
attach_metadata_full_frame (dsexample, frame_meta, scale_ratio, output, i);
i++;
int person_count = 0;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next)
obj_meta = (NvDsObjectMeta *) (l_obj->data);
/* Should not process on objects smaller than MIN_INPUT_OBJECT_WIDTH x MIN_INPUT_OBJECT_HEIGHT
* since it will cause hardware scaling issues. */
if (obj_meta->rect_params.width < MIN_INPUT_OBJECT_WIDTH ||
obj_meta->rect_params.height < MIN_INPUT_OBJECT_HEIGHT)
continue;
// Crop and scale the object
surface, frame_meta->batch_id, &obj_meta->rect_params,
// Error in conversion, skip processing on object. */
continue;
// Process the object crop to obtain label
output = DsExampleProcess (dsexample->dsexamplelib_ctx,
// Attach labels for the object
char *text=obj_meta->text_params.display_text;
// Get the bounding box center matching point in line
// Get the slope of the line
float m = (dsexample->y_coordinate_bottom - dsexample->y_coordinate_top) / (dsexample->x_coordinate_bottom - dsexample->x_coordinate_top);
//std::cout << dsexample->x_coordinate_top << std::endl;
if(strcmp(text,"person") == 0 and obj_meta->rect_params.left + obj_meta->rect_params.width >= 640) {
person_count = person_count + 1;
attach_metadata_object (dsexample, obj_meta, output);
free (output);
if(person_count == 0)
std::cout << "No person" << std::endl;
//std::string filename1 = "/home/uh5190/python_scripts/UDPsendno.py";
//std::string command1 = "python ";
//command1 += filename1;
//system(command1.c_str());
else
std::cout << "Warning !!! Person detected" << std::endl;
//std::string filename = "/home/uh5190/python_scripts/UDPsendyes.py";
//std::string command = "python ";
//command += filename;
//system(command.c_str());
} else {
continue;
continue;
free (output);
flow_ret = GST_FLOW_OK;
error:
gst_buffer_unmap (inbuf, &in_map_info);
return flow_ret;
* Attach metadata for the full frame. We will be adding a new metadata.
static void
NvDsBatchMeta *batch_meta = frame_meta->base_meta.batch_meta;
NvDsObjectMeta *object_meta = NULL;
NvDsDisplayMeta *display_meta = NULL;
static gchar font_name[] = "Serif";
GST_DEBUG_OBJECT (dsexample, "Attaching metadata %d\n", output->numObjects);
for (gint i = 0; i < output->numObjects; i++) {
DsExampleObject *obj = &output->object[i];
object_meta = nvds_acquire_obj_meta_from_pool(batch_meta);
NvOSD_RectParams & rect_params = object_meta->rect_params;
NvOSD_TextParams & text_params = object_meta->text_params;
// Assign bounding box coordinates
rect_params.left = obj->left;
rect_params.top = obj->top;
rect_params.width = obj->width;
rect_params.height = obj->height;
/*rect_params.left = 640;
rect_params.width = 640;
rect_params.height = 720;
// Semi-transparent yellow background
rect_params.has_bg_color = 0;
rect_params.bg_color = (NvOSD_ColorParams) {
1, 1, 0, 0.4};
// Red border of width 6
rect_params.border_width = 3;
rect_params.border_color = (NvOSD_ColorParams) {
1, 0, 0, 1};
// Scale the bounding boxes proportionally based on how the object/frame was
// scaled during input
rect_params.left /= scale_ratio;
rect_params.top /= scale_ratio;
rect_params.width /= scale_ratio;
rect_params.height /= scale_ratio;
GST_DEBUG_OBJECT (dsexample, "Attaching rect%d of batch%u"
" left->%u top->%u width->%u"
" height->%u label->%s\n", i, batch_id, rect_params.left,
rect_params.top, rect_params.width, rect_params.height, obj->label);
object_meta->object_id = UNTRACKED_OBJECT_ID;
g_strlcpy (object_meta->obj_label, obj->label, MAX_LABEL_SIZE);
// display_text required heap allocated memory
text_params.display_text = g_strdup (obj->label);
// Display text above the left top corner of the object
text_params.x_offset = rect_params.left;
text_params.y_offset = rect_params.top - 10;
// Set black background for the text
text_params.set_bg_clr = 1;
text_params.text_bg_clr = (NvOSD_ColorParams) {
0, 0, 0, 1};
// Font face, size and color
text_params.font_params.font_name = font_name;
text_params.font_params.font_size = 11;
text_params.font_params.font_color = (NvOSD_ColorParams) {
1, 1, 1, 1};*/
//for demonstration, user need to se these values
display_meta = nvds_acquire_display_meta_from_pool (batch_meta);
NvOSD_LineParams *line_params = display_meta->line_params;
line_params[0].x1 = dsexample->x_coordinate_top;
line_params[0].y1 = dsexample->y_coordinate_top;
line_params[0].x2 = dsexample->x_coordinate_bottom;
line_params[0].y2 = dsexample->y_coordinate_bottom;
line_params[0].line_width = 3;
line_params[0].line_color = (NvOSD_ColorParams){ 1, 0, 0, 1};
display_meta->num_lines++;
//nvds_add_obj_meta_to_frame(frame_meta, object_meta, NULL);
nvds_add_display_meta_to_frame (frame_meta, display_meta);
* Only update string label in an existing object metadata. No bounding boxes.
* We assume only one label per object is generated
static void
attach_metadata_object (GstDsExample * dsexample, NvDsObjectMeta * obj_meta,
if (output->numObjects == 0)
return;
NvDsBatchMeta *batch_meta = obj_meta->base_meta.batch_meta;
NvDsClassifierMeta *classifier_meta =
nvds_acquire_classifier_meta_from_pool (batch_meta);
classifier_meta->unique_component_id = dsexample->unique_id;
NvDsLabelInfo *label_info =
nvds_acquire_label_info_meta_from_pool (batch_meta);
g_strlcpy (label_info->result_label, output->object[0].label, MAX_LABEL_SIZE);
nvds_add_label_info_meta_to_classifier(classifier_meta, label_info);
nvds_add_classifier_meta_to_object (obj_meta, classifier_meta);
nvds_acquire_meta_lock (batch_meta);
NvOSD_TextParams & text_params = obj_meta->text_params;
NvOSD_RectParams & rect_params = obj_meta->rect_params;
/* Below code to display the result */
if (text_params.display_text) {
gchar *conc_string = g_strconcat (text_params.display_text, " ",
output->object[0].label, NULL);
g_free (text_params.display_text);
text_params.display_text = conc_string;
} else {
text_params.display_text = g_strdup (output->object[0].label);
text_params.font_params.font_name = (char *)"Serif";
1, 1, 1, 1};
0, 0, 0, 1};
nvds_release_meta_lock (batch_meta);
* Boiler plate for registering a plugin and an element.
static gboolean
dsexample_plugin_init (GstPlugin * plugin)
GST_DEBUG_CATEGORY_INIT (gst_dsexample_debug, "dsexample", 0,
"dsexample plugin");
return gst_element_register (plugin, "dsexample", GST_RANK_PRIMARY,
GST_TYPE_DSEXAMPLE);
GST_PLUGIN_DEFINE (GST_VERSION_MAJOR,
GST_VERSION_MINOR,
nvdsgst_dsexample,
DESCRIPTION, dsexample_plugin_init, DS_VERSION, LICENSE, BINARY_PACKAGE, URL)
But when I print those values inside the gst_dsexample_transform_ip() function I get the default values I have set on line 80-83 on the above code. It doesn’t get the values from the config file. The issue is only for the new parameters I added. Please tell me, what did I miss when adding the new parameters.
