• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 5.0 GA
• JetPack Version (valid for Jetson only) R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t210ref, EABI: aarch64
• TensorRT Version
Hello, I am using deepstream-app on Jetson Nano with dsexample=1. My gstdsexample.cpp looks like this:
* Copyright (c) 2017-2020, NVIDIA CORPORATION. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
#include <string.h>
#include <string>
#include <sstream>
#include <iostream>
#include <ostream>
#include <fstream>
#include "gstdsexample.h"
#include <sys/time.h>
GST_DEBUG_CATEGORY_STATIC (gst_dsexample_debug);
#define GST_CAT_DEFAULT gst_dsexample_debug
#define USE_EGLIMAGE 1
/* enable to write transformed cvmat to files */
/* #define DSEXAMPLE_DEBUG */
static GQuark _dsmeta_quark = 0;
/* Enum to identify properties */
enum
PROP_0,
PROP_UNIQUE_ID,
PROP_PROCESSING_WIDTH,
PROP_PROCESSING_HEIGHT,
PROP_PROCESS_FULL_FRAME,
PROP_BLUR_OBJECTS,
PROP_GPU_DEVICE_ID
#define NVDS_USER_FRAME_META_EXAMPLE (nvds_get_user_meta_type("NVIDIA.NVINFER.USER_META"))
#define CHECK_NVDS_MEMORY_AND_GPUID(object, surface) \
({ int _errtype=0;\
do { \
if ((surface->memType == NVBUF_MEM_DEFAULT || surface->memType == NVBUF_MEM_CUDA_DEVICE) && \
(surface->gpuId != object->gpu_id)) { \
GST_ELEMENT_ERROR (object, RESOURCE, FAILED, \
("Input surface gpu-id doesnt match with configured gpu-id for element," \
" please allocate input using unified memory, or use same gpu-ids"),\
("surface-gpu-id=%d,%s-gpu-id=%d",surface->gpuId,GST_ELEMENT_NAME(object),\
object->gpu_id)); \
_errtype = 1;\
} while(0); \
_errtype; \
/* Default values for properties */
#define DEFAULT_UNIQUE_ID 15
#define DEFAULT_PROCESSING_WIDTH 640
#define DEFAULT_PROCESSING_HEIGHT 480
#define DEFAULT_PROCESS_FULL_FRAME TRUE
#define DEFAULT_BLUR_OBJECTS FALSE
#define DEFAULT_GPU_ID 0
#define RGB_BYTES_PER_PIXEL 3
#define RGBA_BYTES_PER_PIXEL 4
#define Y_BYTES_PER_PIXEL 1
#define UV_BYTES_PER_PIXEL 2
#define MIN_INPUT_OBJECT_WIDTH 16
#define MIN_INPUT_OBJECT_HEIGHT 16
#define CHECK_NPP_STATUS(npp_status,error_str) do { \
if ((npp_status) != NPP_SUCCESS) { \
g_print ("Error: %s in %s at line %d: NPP Error %d\n", \
error_str, __FILE__, __LINE__, npp_status); \
goto error; \
} while (0)
#define CHECK_CUDA_STATUS(cuda_status,error_str) do { \
if ((cuda_status) != cudaSuccess) { \
g_print ("Error: %s in %s at line %d (%s)\n", \
error_str, __FILE__, __LINE__, cudaGetErrorName(cuda_status)); \
goto error; \
} while (0)
/* By default NVIDIA Hardware allocated memory flows through the pipeline. We
* will be processing on this type of memory only. */
#define GST_CAPS_FEATURE_MEMORY_NVMM "memory:NVMM"
static GstStaticPadTemplate gst_dsexample_sink_template =
GST_STATIC_PAD_TEMPLATE ("sink",
GST_PAD_SINK,
GST_PAD_ALWAYS,
GST_STATIC_CAPS (GST_VIDEO_CAPS_MAKE_WITH_FEATURES
(GST_CAPS_FEATURE_MEMORY_NVMM,
"{ NV12, RGBA, I420 }")));
static GstStaticPadTemplate gst_dsexample_src_template =
GST_STATIC_PAD_TEMPLATE ("src",
GST_PAD_SRC,
GST_PAD_ALWAYS,
/* Define our element type. Standard GObject/GStreamer boilerplate stuff */
#define gst_dsexample_parent_class parent_class
G_DEFINE_TYPE (GstDsExample, gst_dsexample, GST_TYPE_BASE_TRANSFORM);
static void gst_dsexample_set_property (GObject * object, guint prop_id,
const GValue * value, GParamSpec * pspec);
static void gst_dsexample_get_property (GObject * object, guint prop_id,
static gboolean gst_dsexample_set_caps (GstBaseTransform * btrans,
GstCaps * incaps, GstCaps * outcaps);
static gboolean gst_dsexample_start (GstBaseTransform * btrans);
static gboolean gst_dsexample_stop (GstBaseTransform * btrans);
static GstFlowReturn gst_dsexample_transform_ip (GstBaseTransform *
btrans, GstBuffer * inbuf);
static void
attach_metadata_full_frame (GstDsExample * dsexample, NvDsFrameMeta *frame_meta,
gdouble scale_ratio, DsExampleOutput * output, guint batch_id);
static void attach_metadata_object (GstDsExample * dsexample,
NvDsObjectMeta * obj_meta, DsExampleOutput * output, cv::Mat newFram);
void *set_metadata_ptr(cv::Mat fram);
static gpointer copy_user_meta(gpointer data, gpointer user_data);
static void release_user_meta(gpointer data, gpointer user_data);
int i = 0;
// gchar *user_metadata = (gchar*)g_malloc0(USER_ARRAY_SIZE);
cv::Mat *user_metadata = (cv::Mat*)g_malloc0(1000);
// g_print("\n**************** Setting user metadata array of 16 on nvinfer src pad\n");
//for(i = 0; i < USER_ARRAY_SIZE; i++) {
// user_metadata[i] = rand() % 255;
// // user_metadata->frame_type = (frame_number % 3);
// // cv::Mat newFrame = cv::imread("/home/sigmind/7.jpg");
// user_metadata->ass = newFrame.clone();//exactFrame.clone();//newFrame.clone();
//cv::Mat receivedFrame;// = NULL;// = cv::imread("/home/sigmind/keanu.jpg");;
// if(frameQueue.size() > 0)
//*receivedFrame = frameQueue.front();
fram.copyTo(*user_metadata);
//fram.release();
//printf("OpenCV in dsEXAMPLE: %s", cv::getBuildInformation().c_str());
//cv::imwrite("/home/imran/Downloads/framecrop/fram.jpg",user_metadata->clone());
// frameQueue.clear();
// receivedFrame.copyTo(*user_metadata);
// receivedFrame.release();
// newFrame.release();
//newFrame.release();
//g_print("user_meta_data [%d] = %d\n", i, user_metadata[i]);
return (void *)user_metadata;
/* copy function set by user. "data" holds a pointer to NvDsUserMeta*/
NvDsUserMeta *user_meta = (NvDsUserMeta *)data;
// gchar *src_user_metadata = (gchar*)user_meta->user_meta_data;
cv::Mat *src_user_metadata = (cv::Mat*)user_meta->user_meta_data;
cv::Mat *dst_user_metadata = (cv::Mat*)g_malloc0(1000);
// src_user_metadata->copyTo(*dst_user_metadata);
// memcpy(dst_user_metadata, src_user_metadata, 1000);
//src_user_metadata->release();
//g_free(*src_user_metadata);
//delete src_user_metadata;
return (gpointer)dst_user_metadata;
// NvDecoderrMeta *src_decoder_meta = (NvDecoderrMeta *)data;
// NvDecoderrMeta *dst_decoder_meta = (NvDecoderrMeta*)g_malloc0(sizeof(NvDecoderrMeta));
// memcpy(dst_decoder_meta, src_decoder_meta, sizeof(NvDecoderrMeta));
// return (gpointer)dst_decoder_meta;
/* release function set by user. "data" holds a pointer to NvDsUserMeta*/
//user_meta->user_meta_data = NULL;
cv::Mat *metadata = (cv::Mat*)user_meta->user_meta_data;
//metadata = NULL;
//(user_meta->user_meta_data)->release();
// if(user_meta->user_meta_data) {
g_free(user_meta->user_meta_data);
// NvDecoderrMeta *decoder_meta = (NvDecoderrMeta *)data;
// if(decoder_meta) {
// g_free(decoder_meta);
// decoder_meta = NULL;
/* Install properties, set sink and src pad capabilities, override the required
* functions of the base class, These are common to all instances of the
* element.
static void
gst_dsexample_class_init (GstDsExampleClass * klass)
GObjectClass *gobject_class;
GstElementClass *gstelement_class;
GstBaseTransformClass *gstbasetransform_class;
/* Indicates we want to use DS buf api */
g_setenv ("DS_NEW_BUFAPI", "1", TRUE);
gobject_class = (GObjectClass *) klass;
gstelement_class = (GstElementClass *) klass;
gstbasetransform_class = (GstBaseTransformClass *) klass;
/* Overide base class functions */
gobject_class->set_property = GST_DEBUG_FUNCPTR (gst_dsexample_set_property);
gobject_class->get_property = GST_DEBUG_FUNCPTR (gst_dsexample_get_property);
gstbasetransform_class->set_caps = GST_DEBUG_FUNCPTR (gst_dsexample_set_caps);
gstbasetransform_class->start = GST_DEBUG_FUNCPTR (gst_dsexample_start);
gstbasetransform_class->stop = GST_DEBUG_FUNCPTR (gst_dsexample_stop);
gstbasetransform_class->transform_ip =
GST_DEBUG_FUNCPTR (gst_dsexample_transform_ip);
/* Install properties */
g_object_class_install_property (gobject_class, PROP_UNIQUE_ID,
g_param_spec_uint ("unique-id",
"Unique ID",
"Unique ID for the element. Can be used to identify output of the"
" element", 0, G_MAXUINT, DEFAULT_UNIQUE_ID, (GParamFlags)
(G_PARAM_READWRITE | G_PARAM_STATIC_STRINGS)));
g_object_class_install_property (gobject_class, PROP_PROCESSING_WIDTH,
g_param_spec_int ("processing-width",
"Processing Width",
"Width of the input buffer to algorithm",
1, G_MAXINT, DEFAULT_PROCESSING_WIDTH, (GParamFlags)
g_object_class_install_property (gobject_class, PROP_PROCESSING_HEIGHT,
g_param_spec_int ("processing-height",
"Processing Height",
"Height of the input buffer to algorithm",
1, G_MAXINT, DEFAULT_PROCESSING_HEIGHT, (GParamFlags)
g_object_class_install_property (gobject_class, PROP_PROCESS_FULL_FRAME,
g_param_spec_boolean ("full-frame",
"Full frame",
"Enable to process full frame or disable to process objects detected"
"by primary detector", DEFAULT_PROCESS_FULL_FRAME, (GParamFlags)
g_object_class_install_property (gobject_class, PROP_BLUR_OBJECTS,
g_param_spec_boolean ("blur-objects",
"Blur Objects",
"Enable to blur the objects detected in full-frame=0 mode"
"by primary detector", DEFAULT_BLUR_OBJECTS, (GParamFlags)
g_object_class_install_property (gobject_class, PROP_GPU_DEVICE_ID,
g_param_spec_uint ("gpu-id",
"Set GPU Device ID",
"Set GPU Device ID", 0,
G_MAXUINT, 0,
GParamFlags
G_PARAM_STATIC_STRINGS | GST_PARAM_MUTABLE_READY)));
/* Set sink and src pad capabilities */
gst_element_class_add_pad_template (gstelement_class,
gst_static_pad_template_get (&gst_dsexample_src_template));
gst_static_pad_template_get (&gst_dsexample_sink_template));
/* Set metadata describing the element */
gst_element_class_set_details_simple (gstelement_class,
"DsExample plugin",
"DsExample Plugin",
"Process a 3rdparty example algorithm on objects / full frame",
"NVIDIA Corporation. Post on Deepstream for Tesla forum for any queries "
"@ https://devtalk.nvidia.com/default/board/209/");
static void
gst_dsexample_init (GstDsExample * dsexample)
GstBaseTransform *btrans = GST_BASE_TRANSFORM (dsexample);
/* We will not be generating a new buffer. Just adding / updating
* metadata. */
gst_base_transform_set_in_place (GST_BASE_TRANSFORM (btrans), TRUE);
/* We do not want to change the input caps. Set to passthrough. transform_ip
* is still called. */
gst_base_transform_set_passthrough (GST_BASE_TRANSFORM (btrans), TRUE);
/* Initialize all property variables to default values */
dsexample->unique_id = DEFAULT_UNIQUE_ID;
dsexample->processing_width = DEFAULT_PROCESSING_WIDTH;
dsexample->processing_height = DEFAULT_PROCESSING_HEIGHT;
dsexample->process_full_frame = DEFAULT_PROCESS_FULL_FRAME;
dsexample->blur_objects = DEFAULT_BLUR_OBJECTS;
dsexample->gpu_id = DEFAULT_GPU_ID;
/* This quark is required to identify NvDsMeta when iterating through
* the buffer metadatas */
if (!_dsmeta_quark)
_dsmeta_quark = g_quark_from_static_string (NVDS_META_STRING);
/* Function called when a property of the element is set. Standard boilerplate.
static void
GstDsExample *dsexample = GST_DSEXAMPLE (object);
switch (prop_id) {
case PROP_UNIQUE_ID:
dsexample->unique_id = g_value_get_uint (value);
break;
case PROP_PROCESSING_WIDTH:
dsexample->processing_width = g_value_get_int (value);
break;
case PROP_PROCESSING_HEIGHT:
dsexample->processing_height = g_value_get_int (value);
break;
case PROP_PROCESS_FULL_FRAME:
dsexample->process_full_frame = g_value_get_boolean (value);
break;
case PROP_BLUR_OBJECTS:
dsexample->blur_objects = g_value_get_boolean (value);
break;
case PROP_GPU_DEVICE_ID:
dsexample->gpu_id = g_value_get_uint (value);
break;
default:
G_OBJECT_WARN_INVALID_PROPERTY_ID (object, prop_id, pspec);
break;
/* Function called when a property of the element is requested. Standard
* boilerplate.
static void
switch (prop_id) {
g_value_set_uint (value, dsexample->unique_id);
break;
g_value_set_int (value, dsexample->processing_width);
break;
g_value_set_int (value, dsexample->processing_height);
break;
g_value_set_boolean (value, dsexample->process_full_frame);
break;
g_value_set_boolean (value, dsexample->blur_objects);
break;
g_value_set_uint (value, dsexample->gpu_id);
break;
default:
break;
* Initialize all resources and start the output thread
static gboolean
GstDsExample *dsexample = GST_DSEXAMPLE (btrans);
NvBufSurfaceCreateParams create_params;
DsExampleInitParams init_params =
{ dsexample->processing_width, dsexample->processing_height,
GstQuery *queryparams = NULL;
guint batch_size = 1;
/* Algorithm specific initializations and resource allocation. */
dsexample->dsexamplelib_ctx = DsExampleCtxInit (&init_params);
GST_DEBUG_OBJECT (dsexample, "ctx lib %p \n", dsexample->dsexamplelib_ctx);
CHECK_CUDA_STATUS (cudaSetDevice (dsexample->gpu_id),
"Unable to set cuda device");
dsexample->batch_size = 1;
queryparams = gst_nvquery_batch_size_new ();
if (gst_pad_peer_query (GST_BASE_TRANSFORM_SINK_PAD (btrans), queryparams)
|| gst_pad_peer_query (GST_BASE_TRANSFORM_SRC_PAD (btrans), queryparams)) {
if (gst_nvquery_batch_size_parse (queryparams, &batch_size)) {
dsexample->batch_size = batch_size;
GST_DEBUG_OBJECT (dsexample, "Setting batch-size %d \n",
dsexample->batch_size);
gst_query_unref (queryparams);
if (dsexample->process_full_frame && dsexample->blur_objects) {
GST_ERROR ("Error: does not support blurring while processing full frame");
goto error;
CHECK_CUDA_STATUS (cudaStreamCreate (&dsexample->cuda_stream),
"Could not create cuda stream");
if (dsexample->inter_buf)
NvBufSurfaceDestroy (dsexample->inter_buf);
dsexample->inter_buf = NULL;
/* An intermediate buffer for NV12/RGBA to BGR conversion will be
* required. Can be skipped if custom algorithm can work directly on NV12/RGBA. */
create_params.gpuId = dsexample->gpu_id;
create_params.width = dsexample->processing_width;
create_params.height = dsexample->processing_height;
create_params.size = 0;
create_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
create_params.layout = NVBUF_LAYOUT_PITCH;
#ifdef __aarch64__
create_params.memType = NVBUF_MEM_DEFAULT;
#else
create_params.memType = NVBUF_MEM_CUDA_UNIFIED;
#endif
if (NvBufSurfaceCreate (&dsexample->inter_buf, 1,
&create_params) != 0) {
GST_ERROR ("Error: Could not allocate internal buffer for dsexample");
goto error;
/* Create host memory for storing converted/scaled interleaved RGB data */
CHECK_CUDA_STATUS (cudaMallocHost (&dsexample->host_rgb_buf,
dsexample->processing_width * dsexample->processing_height *
RGB_BYTES_PER_PIXEL), "Could not allocate cuda host buffer");
GST_DEBUG_OBJECT (dsexample, "allocated cuda buffer %p \n",
dsexample->host_rgb_buf);
/* CV Mat containing interleaved RGB data. This call does not allocate memory.
* It uses host_rgb_buf as data. */
dsexample->cvmat =
new cv::Mat (dsexample->processing_height, dsexample->processing_width,
CV_8UC3, dsexample->host_rgb_buf,
dsexample->processing_width * RGB_BYTES_PER_PIXEL);
if (!dsexample->cvmat)
goto error;
GST_DEBUG_OBJECT (dsexample, "created CV Mat\n");
return TRUE;
error:
if (dsexample->host_rgb_buf) {
cudaFreeHost (dsexample->host_rgb_buf);
dsexample->host_rgb_buf = NULL;
if (dsexample->cuda_stream) {
cudaStreamDestroy (dsexample->cuda_stream);
dsexample->cuda_stream = NULL;
if (dsexample->dsexamplelib_ctx)
DsExampleCtxDeinit (dsexample->dsexamplelib_ctx);
return FALSE;
* Stop the output thread and free up all the resources
static gboolean
NvBufSurfaceDestroy(dsexample->inter_buf);
delete dsexample->cvmat;
dsexample->cvmat = NULL;
GST_DEBUG_OBJECT (dsexample, "deleted CV Mat \n");
/* Deinit the algorithm library */
dsexample->dsexamplelib_ctx = NULL;
GST_DEBUG_OBJECT (dsexample, "ctx lib released \n");
return TRUE;
* Called when source / sink pad capabilities have been negotiated.
static gboolean
gst_dsexample_set_caps (GstBaseTransform * btrans, GstCaps * incaps,
GstCaps * outcaps)
/* Save the input video information, since this will be required later. */
gst_video_info_from_caps (&dsexample->video_info, incaps);
if (dsexample->blur_objects && !dsexample->process_full_frame) {
/* requires RGBA format for blurring the objects in opencv */
if (dsexample->video_info.finfo->format != GST_VIDEO_FORMAT_RGBA) {
GST_ELEMENT_ERROR (dsexample, STREAM, FAILED,
("input format should be RGBA when using blur-objects property"), (NULL));
goto error;
return TRUE;
error:
return FALSE;
* Scale the entire frame to the processing resolution maintaining aspect ratio.
* Or crop and scale objects to the processing resolution maintaining the aspect
* ratio. Remove the padding required by hardware and convert from RGBA to RGB
* using openCV. These steps can be skipped if the algorithm can work with
* padded data and/or can work with RGBA.
get_converted_mat (GstDsExample * dsexample, NvBufSurface *input_buf, gint idx,
NvOSD_RectParams * crop_rect_params, gdouble & ratio, gint input_width,
gint input_height)
NvBufSurfTransform_Error err;
NvBufSurfTransformConfigParams transform_config_params;
NvBufSurfTransformParams transform_params;
NvBufSurfTransformRect src_rect;
NvBufSurfTransformRect dst_rect;
NvBufSurface ip_surf;
cv::Mat in_mat;
ip_surf = *input_buf;
ip_surf.numFilled = ip_surf.batchSize = 1;
ip_surf.surfaceList = &(input_buf->surfaceList[idx]);
gint src_left = GST_ROUND_UP_2((unsigned int)crop_rect_params->left);
gint src_top = GST_ROUND_UP_2((unsigned int)crop_rect_params->top);
gint src_width = GST_ROUND_DOWN_2((unsigned int)crop_rect_params->width);
gint src_height = GST_ROUND_DOWN_2((unsigned int)crop_rect_params->height);
/* Maintain aspect ratio */
double hdest = dsexample->processing_width * src_height / (double) src_width;
double wdest = dsexample->processing_height * src_width / (double) src_height;
guint dest_width, dest_height;
if (hdest <= dsexample->processing_height) {
dest_width = dsexample->processing_width;
dest_height = hdest;
} else {
dest_width = wdest;
dest_height = dsexample->processing_height;
/* Configure transform session parameters for the transformation */
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
transform_config_params.gpu_id = dsexample->gpu_id;
transform_config_params.cuda_stream = dsexample->cuda_stream;
/* Set the transform session parameters for the conversions executed in this
* thread. */
err = NvBufSurfTransformSetSessionParams (&transform_config_params);
if (err != NvBufSurfTransformError_Success) {
("NvBufSurfTransformSetSessionParams failed with error %d", err), (NULL));
goto error;
/* Calculate scaling ratio while maintaining aspect ratio */
ratio = MIN (1.0 * dest_width/ src_width, 1.0 * dest_height / src_height);
if ((crop_rect_params->width == 0) || (crop_rect_params->height == 0)) {
("%s:crop_rect_params dimensions are zero",__func__), (NULL));
goto error;
#ifdef __aarch64__
if (ratio <= 1.0 / 16 || ratio >= 16.0) {
/* Currently cannot scale by ratio > 16 or < 1/16 for Jetson */
goto error;
#endif
/* Set the transform ROIs for source and destination */
src_rect = {(guint)src_top, (guint)src_left, (guint)src_width, (guint)src_height};
dst_rect = {0, 0, (guint)dest_width, (guint)dest_height};
/* Set the transform parameters */
transform_params.src_rect = &src_rect;
transform_params.dst_rect = &dst_rect;
transform_params.transform_flag =
NVBUFSURF_TRANSFORM_FILTER | NVBUFSURF_TRANSFORM_CROP_SRC |
NVBUFSURF_TRANSFORM_CROP_DST;
transform_params.transform_filter = NvBufSurfTransformInter_Default;
/* Memset the memory */
NvBufSurfaceMemSet (dsexample->inter_buf, 0, 0, 0);
GST_DEBUG_OBJECT (dsexample, "Scaling and converting input buffer\n");
/* Transformation scaling+format conversion if any. */
err = NvBufSurfTransform (&ip_surf, dsexample->inter_buf, &transform_params);
("NvBufSurfTransform failed with error %d while converting buffer", err),
(NULL));
goto error;
/* Map the buffer so that it can be accessed by CPU */
if (NvBufSurfaceMap (dsexample->inter_buf, 0, 0, NVBUF_MAP_READ) != 0){
goto error;
/* Cache the mapped data for CPU access */
NvBufSurfaceSyncForCpu (dsexample->inter_buf, 0, 0);
/* Use openCV to remove padding and convert RGBA to BGR. Can be skipped if
* algorithm can handle padded RGBA data. */
in_mat =
CV_8UC4, dsexample->inter_buf->surfaceList[0].mappedAddr.addr[0],
dsexample->inter_buf->surfaceList[0].pitch);
#if (CV_MAJOR_VERSION >= 4)
cv::cvtColor (in_mat, *dsexample->cvmat, cv::COLOR_RGBA2BGR);
#else
cv::cvtColor (in_mat, *dsexample->cvmat, CV_RGBA2RGB);
#endif
if (NvBufSurfaceUnMap (dsexample->inter_buf, 0, 0)){
goto error;
#ifdef __aarch64__
/* To use the converted buffer in CUDA, create an EGLImage and then use
* CUDA-EGL interop APIs */
if (USE_EGLIMAGE) {
if (NvBufSurfaceMapEglImage (dsexample->inter_buf, 0) !=0 ) {
goto error;
/* dsexample->inter_buf->surfaceList[0].mappedAddr.eglImage
* Use interop APIs cuGraphicsEGLRegisterImage and
* cuGraphicsResourceGetMappedEglFrame to access the buffer in CUDA */
/* Destroy the EGLImage */
NvBufSurfaceUnMapEglImage (dsexample->inter_buf, 0);
#endif
/* We will first convert only the Region of Interest (the entire frame or the
* object bounding box) to RGB and then scale the converted RGB frame to
* processing resolution. */
return GST_FLOW_OK;
error:
return GST_FLOW_ERROR;
* Blur the detected objects when processing in object mode (full-frame=0)
blur_objects (GstDsExample * dsexample, gint idx,
NvOSD_RectParams * crop_rect_params, cv::Mat in_mat)
cv::Rect crop_rect;
/* rectangle for cropped objects */
crop_rect = cv::Rect (crop_rect_params->left, crop_rect_params->top,
crop_rect_params->width, crop_rect_params->height);
/* apply gaussian blur to the detected objects */
GaussianBlur(in_mat(crop_rect), in_mat(crop_rect), cv::Size(15,15), 4);
return GST_FLOW_OK;
* Called when element recieves an input buffer from upstream element.
gst_dsexample_transform_ip (GstBaseTransform * btrans, GstBuffer * inbuf)
GstMapInfo in_map_info;
GstFlowReturn flow_ret = GST_FLOW_ERROR;
gdouble scale_ratio = 1.0;
DsExampleOutput *output;
NvBufSurface *surface = NULL;
NvDsBatchMeta *batch_meta = NULL;
NvDsFrameMeta *frame_meta = NULL;
NvDsMetaList * l_frame = NULL;
guint i = 0;
dsexample->frame_num++;
memset (&in_map_info, 0, sizeof (in_map_info));
if (!gst_buffer_map (inbuf, &in_map_info, GST_MAP_READ)) {
g_print ("Error: Failed to map gst buffer\n");
goto error;
surface = (NvBufSurface *) in_map_info.data;
"Processing Frame %" G_GUINT64_FORMAT " Surface %p\n",
dsexample->frame_num, surface);
if (CHECK_NVDS_MEMORY_AND_GPUID (dsexample, surface))
goto error;
batch_meta = gst_buffer_get_nvds_batch_meta (inbuf);
if (batch_meta == nullptr) {
("NvDsBatchMeta not found for input buffer."), (NULL));
if (dsexample->process_full_frame) {
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next)
frame_meta = (NvDsFrameMeta *) (l_frame->data);
NvOSD_RectParams rect_params;
/* Scale the entire frame to processing resolution */
rect_params.left = 0;
rect_params.top = 0;
rect_params.width = dsexample->video_info.width;
rect_params.height = dsexample->video_info.height;
/* Scale and convert the frame */
if (get_converted_mat (dsexample, surface, i, &rect_params,
scale_ratio, dsexample->video_info.width,
dsexample->video_info.height) != GST_FLOW_OK) {
goto error;
/* Process to get the output */
output =
DsExampleProcess (dsexample->dsexamplelib_ctx,
dsexample->cvmat->data);
/* Attach the metadata for the full frame */
attach_metadata_full_frame (dsexample, frame_meta, scale_ratio, output, i);
i++;
free (output);
} else {
/* Using object crops as input to the algorithm. The objects are detected by
* the primary detector */
NvDsMetaList * l_obj = NULL;
NvDsObjectMeta *obj_meta = NULL;
#ifndef __aarch64__
if (dsexample->blur_objects) {
if (surface->memType != NVBUF_MEM_CUDA_UNIFIED){
("%s:need NVBUF_MEM_CUDA_UNIFIED memory for opencv blurring",__func__), (NULL));
#endif
cv::Mat in_mat;
if (surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0] == NULL){
if (NvBufSurfaceMap (surface, frame_meta->batch_id, 0, NVBUF_MAP_READ_WRITE) != 0){
("%s:buffer map to be accessed by CPU failed", __func__), (NULL));
NvBufSurfaceSyncForCpu (surface, frame_meta->batch_id, 0);
in_mat =
cv::Mat (surface->surfaceList[frame_meta->batch_id].planeParams.height[0],
surface->surfaceList[frame_meta->batch_id].planeParams.width[0], CV_8UC4,
surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0],
surface->surfaceList[frame_meta->batch_id].planeParams.pitch[0]);
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next)
obj_meta = (NvDsObjectMeta *) (l_obj->data);
/* gaussian blur the detected objects using opencv */
if (blur_objects (dsexample, frame_meta->batch_id,
&obj_meta->rect_params, in_mat) != GST_FLOW_OK) {
/* Error in blurring, skip processing on object. */
("blurring the object failed"), (NULL));
if (NvBufSurfaceUnMap (surface, frame_meta->batch_id, 0)){
("%s:buffer unmap to be accessed by CPU failed", __func__), (NULL));
continue;
/* Should not process on objects smaller than MIN_INPUT_OBJECT_WIDTH x MIN_INPUT_OBJECT_HEIGHT
* since it will cause hardware scaling issues. */
if (obj_meta->rect_params.width < MIN_INPUT_OBJECT_WIDTH ||
obj_meta->rect_params.height < MIN_INPUT_OBJECT_HEIGHT)
continue;
/* Crop and scale the object */
surface, frame_meta->batch_id, &obj_meta->rect_params,
/* Error in conversion, skip processing on object. */
continue;
/* Process the object crop to obtain label */
output = DsExampleProcess (dsexample->dsexamplelib_ctx,
/* Attach labels for the object */
NvBufSurfaceSyncForDevice (surface, frame_meta->batch_id, 0);
//#if (CV_MAJOR_VERSION >= 4)
// cv::cvtColor (in_mat, *dsexample->cvmat, cv::COLOR_RGBA2BGR);
//#else
// cv::cvtColor (in_mat, *dsexample->cvmat, CV_RGBA2BGR);
/* used to dump the converted mat to files for debug */
//static guint cnt = 0;
// cv::imwrite("out_" + std::to_string (cnt) + ".jpeg", *dsexample->cvmat);
// cnt++;
attach_metadata_object (dsexample, obj_meta, output,*dsexample->cvmat);
free (output);
flow_ret = GST_FLOW_OK;
error:
gst_buffer_unmap (inbuf, &in_map_info);
return flow_ret;
* Attach metadata for the full frame. We will be adding a new metadata.
static void
NvDsBatchMeta *batch_meta = frame_meta->base_meta.batch_meta;
NvDsObjectMeta *object_meta = NULL;
static gchar font_name[] = "Serif";
GST_DEBUG_OBJECT (dsexample, "Attaching metadata %d\n", output->numObjects);
for (gint i = 0; i < output->numObjects; i++) {
DsExampleObject *obj = &output->object[i];
object_meta = nvds_acquire_obj_meta_from_pool(batch_meta);
NvOSD_RectParams & rect_params = object_meta->rect_params;
NvOSD_TextParams & text_params = object_meta->text_params;
/* Assign bounding box coordinates */
rect_params.left = obj->left;
rect_params.top = obj->top;
rect_params.width = obj->width;
rect_params.height = obj->height;
/* Semi-transparent yellow background */
rect_params.has_bg_color = 0;
rect_params.bg_color = (NvOSD_ColorParams) {
1, 1, 0, 0.4};
/* Red border of width 6 */
rect_params.border_width = 3;
rect_params.border_color = (NvOSD_ColorParams) {
1, 0, 0, 1};
/* Scale the bounding boxes proportionally based on how the object/frame was
* scaled during input */
rect_params.left /= scale_ratio;
rect_params.top /= scale_ratio;
rect_params.width /= scale_ratio;
rect_params.height /= scale_ratio;
GST_DEBUG_OBJECT (dsexample, "Attaching rect%d of batch%u"
" left->%f top->%f width->%f"
" height->%f label->%s\n", i, batch_id, rect_params.left,
rect_params.top, rect_params.width, rect_params.height, obj->label);
object_meta->object_id = UNTRACKED_OBJECT_ID;
g_strlcpy (object_meta->obj_label, obj->label, MAX_LABEL_SIZE);
/* display_text required heap allocated memory */
text_params.display_text = g_strdup (obj->label);
/* Display text above the left top corner of the object */
text_params.x_offset = rect_params.left;
text_params.y_offset = rect_params.top - 10;
/* Set black background for the text */
text_params.set_bg_clr = 1;
text_params.text_bg_clr = (NvOSD_ColorParams) {
0, 0, 0, 1};
/* Font face, size and color */
text_params.font_params.font_name = font_name;
text_params.font_params.font_size = 11;
text_params.font_params.font_color = (NvOSD_ColorParams) {
1, 1, 1, 1};
nvds_add_obj_meta_to_frame(frame_meta, object_meta, NULL);
frame_meta->bInferDone = TRUE;
* Only update string label in an existing object metadata. No bounding boxes.
* We assume only one label per object is generated
static void
attach_metadata_object (GstDsExample * dsexample, NvDsObjectMeta * obj_meta,
NvDsUserMeta *user_meta = NULL;
NvDsMetaType user_meta_type = NVDS_USER_FRAME_META_EXAMPLE;
if (output->numObjects == 0)
return;
NvDsBatchMeta *batch_meta = obj_meta->base_meta.batch_meta;
NvDsClassifierMeta *classifier_meta =
nvds_acquire_classifier_meta_from_pool (batch_meta);
classifier_meta->unique_component_id = dsexample->unique_id;
NvDsLabelInfo *label_info =
nvds_acquire_label_info_meta_from_pool (batch_meta);
g_strlcpy (label_info->result_label, output->object[0].label, MAX_LABEL_SIZE);
nvds_add_label_info_meta_to_classifier(classifier_meta, label_info);
nvds_add_classifier_meta_to_object (obj_meta, classifier_meta);
nvds_acquire_meta_lock (batch_meta);
user_meta = nvds_acquire_user_meta_from_pool(batch_meta);
//src_meta_data = (cv::Mat *)user_meta->user_meta_data;
if( newFram.empty() ) // Check for invalid input
std::cout << "newFram empty image" << std::endl ;
//return -1;
/* Set NvDsUserMeta below */
user_meta->user_meta_data = (void *)set_metadata_ptr(newFram);
user_meta->base_meta.meta_type = user_meta_type;
user_meta->base_meta.copy_func = (NvDsMetaCopyFunc)copy_user_meta;
user_meta->base_meta.release_func = (NvDsMetaReleaseFunc)release_user_meta;
/* We want to add NvDsUserMeta to frame level */
nvds_add_user_meta_to_obj(obj_meta, user_meta);
// NvOSD_TextParams & text_params = obj_meta->text_params;
// NvOSD_RectParams & rect_params = obj_meta->rect_params;
/* Below code to display the result */
nvds_release_meta_lock (batch_meta);
* Boiler plate for registering a plugin and an element.
static gboolean
dsexample_plugin_init (GstPlugin * plugin)
GST_DEBUG_CATEGORY_INIT (gst_dsexample_debug, "dsexample", 0,
"dsexample plugin");
return gst_element_register (plugin, "dsexample", GST_RANK_PRIMARY,
GST_TYPE_DSEXAMPLE);
GST_PLUGIN_DEFINE (GST_VERSION_MAJOR,
GST_VERSION_MINOR,
nvdsgst_dsexample,
DESCRIPTION, dsexample_plugin_init, DS_VERSION, LICENSE, BINARY_PACKAGE, URL)
Whenever I run the program, it runs fine but I see the error msg in console:
NvMapMemCacheMaint Bad parameter
nvbusurface: NvBufSurfaceSyncForCpu: Error(4) in sync
Is there anything I am doing wrong? I am trying to attach the cropped cv::mat with object meta.
