Hi everyone:
I run the separable convolution code in the sdk example. And I found the kernelradius is specified regardless of the smoothlevel of the Gaussian kernel(the sigma). If I want that the kernelradius is depending on the sigma of the Gaussian . For example, kernelradius = 4 * sigma. Then the kernel_w and kernel radius become variable not constant value. As we all know, in the C language, the size of array must be a constant value. For example, int a[5]; not kernelradius = 4 * sigma;
int a[kerelradius];.
In C language , I can use “malloc“ function to allocate memory dynamically. But in cuda kernel , which function I can use to allocate memory dynamically.
The following is some sentence in the separable convolution code. If the kernel_w and kernel _radius is variables, the following sentence is wrong. How can I change it, which function I can use to allocate memory dynamically in cuda kernel.
device constant float d_Kernel[KERNEL_W];
shared float data[KERNEL_RADIUS + ROW_TILE_W + KERNEL_RADIUS];
Thank you and best regards.
