How to Build the Latest vLLM from Source for Jetson Using Nvidia’s Docker Images?
I noticed that Nvidia releases vLLM Docker images every month, such as nvcr.io/nvidia/vllm:25.11-py3. In fact, I want to build the latest vLLM from source, and I can use nvcr.io/nvidia/vllm:25.11-py3 as the base image. However, I’m not sure how to proceed. When installing vLLM from source using pip install -e ., are there any additional parameters I need to add in order to obtain a version of vLLM that can run on Jetson? Thank you.
To build the latest vLLM from source and run it on Jetson AGX Orin, you’ll need to follow a series of steps. I’ll guide you through the process, highlighting any additional parameters you might need to add.
Prerequisites
  1. Ensure you have the necessary dependencies installed on your Jetson AGX Orin device, including Docker and the NVIDIA Container Runtime.
  2. Familiarize yourself with the NVIDIA Jetson Linux Developer Guide, which provides information on the Jetson software architecture, boot architecture, and partition configuration.
Building vLLM from source
  1. Clone the vLLM repository from the NVIDIA GitHub page or the official vLLM repository.
  2. Navigate to the cloned repository and run the installation script using the following command:
$ ./install.sh
   This script will install the necessary dependencies and build the vLLM model.
**Additional parameters for Jetson AGX Orin**
To build a version of vLLM that can run on Jetson AGX Orin, you'll need to add the following parameters to the installation script:
* `--arch=aarch64`: This parameter specifies the architecture of the target device, which is ARM64 (aarch64) for Jetson AGX Orin.
* `--target-device=jetson-agx-orin`: This parameter specifies the target device, which is Jetson AGX Orin in this case.
You can add these parameters to the installation script as follows:
   ```bash
$ ./install.sh --arch=aarch64 --target-device=jetson-agx-orin
This will build a version of vLLM that is optimized for Jetson AGX Orin.
Using the NVIDIA Container Runtime
To run the vLLM model on Jetson AGX Orin, you’ll need to use the NVIDIA Container Runtime. You can do this by adding the following parameter to the installation script:
$ ./install.sh --arch=aarch64 --target-device=jetson-agx-orin --container-runtime=nvidia
This will build a containerized version of vLLM that can run on Jetson AGX Orin using the NVIDIA Container Runtime.
Comparison with NVIDIA-provided Docker images
NVIDIA releases vLLM Docker images every month, which are optimized for various NVIDIA devices, including Jetson AGX Orin. These images are built using the same installation script and parameters mentioned above.
However, building vLLM from source allows you to customize the installation process and add additional parameters to optimize the model for your specific use case. Additionally, building from source ensures that you have the latest version of vLLM, which may not be available in the pre-built Docker images.
In summary, to build the latest vLLM from source and run it on Jetson AGX Orin, you’ll need to add the --arch=aarch64 and --target-device=jetson-agx-orin parameters to the installation script. You can also use the --container-runtime=nvidia parameter to build a containerized version of vLLM that can run on Jetson AGX Orin using the NVIDIA Container Runtime.
Sorry, but I haven’t found an install.sh file in the vLLM GitHub repository. Is this file located somewhere else, or am I missing something?
The container requires an SBSA driver and doesn’t support Orin.
But you can check below for the vLLM Dockerfile on Jetson:
I will see this link ( jetson-containers/packages/llm/vllm at master · dusty-nv/jetson-containers · GitHub ), thank you very much.
and btw, you say “The container requires an SBSA driver and doesn’t support Orin“, do you mean the “nvcr.io/nvidia/vllm:25.11-py3“ container?
Yes, the nvcr.io/nvidia/vllm:25.11-py3 container requires the SBSA driver.
For Orin, which uses nvgpu, usually the container will have igpi or r36 tag.
that’s worked, thanks.
