I am curious about how to capture objects image after object detection.(1st GIE)
I think that I have to get images from OSD (RGBA) by using metadata info with Frame buffer so I read this doc below
[url]NVIDIA DeepStream SDK API Reference: Main Page
Could you give me advice about this?
I am developing a program about cropping images after I refered to test2/3 sample
I checked RTSP / FILE was working well
DeepStream
uridecodedbin → nvstreammux- → nvinfer → nvtracker → nvinfer → nvinfer → nvinfer → nvvideoconvert → nvdsosd → nvegltransform → nveglglessink
and then added NvBufSurfTransform into osd_sink_pad_buffer_probe
I met error messages after executing my program
Error Message
NvRmChannelSubmit: NvError_IoctlFailed with error code 22
NvRmPrivFlush: NvRmChannelSubmit failed (err = 196623, SyncPointIdx = 54, SyncPointValue = 0)
I read this issue
in my case, I didn’t use createNvBuffer and NvBufSurfaceDestroy, only used NvBufSurfTransform based on GstBuffer
https://devtalk.nvidia.com/default/topic/1035330/jetson-tx2/-mmapi-r28-2-r28-1-deinitplane-of-nvvideoencoder-memory-leak-/1
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info, gpointer u_data)
GstMapInfo in_map_info;
gdouble scale_ratio = 1.0;
NvBufSurface * surface;
NvBufSurfTransformConfigParams transform_config_params;
NvBufSurfTransformParams transform_params;
NvBufSurfTransformRect src_rect;
NvBufSurfTransformRect dst_rect;
NvOSD_RectParams * crop_rect_params;
NvBufSurfTransform_Error err;
[b] memset (&in_map_info, 0, sizeof (in_map_info));
if (!gst_buffer_map (buf, &in_map_info, GST_MAP_READ)) {
g_print ("Error: Failed to map gst buffer\n");
surface = (NvBufSurface *) in_map_info.data;[/b]
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
transform_config_params.gpu_id = 0;
transform_config_params.cuda_stream = cuda_stream; // already called cudaStreamCreate()
// Set the transform session parameters for the conversions executed in this
// thread.
err = NvBufSurfTransformSetSessionParams (&transform_config_params);
if (err != NvBufSurfTransformError_Success) {
g_print ("NvBufSurfTransformSetSessionParams failed with error %d", err);
crop_rect_params = &obj_meta->rect_params;
gint src_left = GST_ROUND_UP_2(crop_rect_params->left);
gint src_top = GST_ROUND_UP_2(crop_rect_params->top);
gint src_width = GST_ROUND_DOWN_2(crop_rect_params->width);
gint src_height = GST_ROUND_DOWN_2(crop_rect_params->height);
// Set the transform ROIs for source and destination
src_rect.top = src_top;
src_rect.left = src_left;
src_rect.width = src_width;
src_rect.height= src_height;
dst_rect.top = 0 + (vehicle_count-1)*240 ;
dst_rect.left = MUXER_OUTPUT_WIDTH-320;
dst_rect.width = 320;
dst_rect.height =240;
// Set the transform parameters
transform_params.src_rect = &src_rect;
transform_params.dst_rect = &dst_rect;
transform_params.transform_flag = NVBUFSURF_TRANSFORM_FILTER | NVBUFSURF_TRANSFORM_CROP_SRC |
NVBUFSURF_TRANSFORM_CROP_DST;
transform_params.transform_filter = NvBufSurfTransformInter_Default;
//printf("fill=%d batch=%d \n ",surface->numFilled,surface->batchSize);
// Transformation scaling+format conversion if any.
<b>err = NvBufSurfTransform (surface, surface, &transform_params);</b>
g_print ("NvBufSurfTransform failed with error %d while converting buffer\n", err);
Please refer to sources/gst-plugins/gst-dsexample/gstdsexample.cpp gst_dsexample_transform_ip()
