Hi team,
I need to do inference on traffic videos, which often contain extremely small people objects. To detect vehicle and people objects in such small sizes, I have tried two methods as below:
1: the 1st one is to add a videoconvert plugin before streammux (right after source bin) in the pipeline:
uridecoder->nvvideoconvert->nvstreammux->nvinfer>nvtracker->nvmultistreamtiler->nvvideoconvert->nvdsosd->nveglglessink
On OSD display, the whole frame is cropped and inference only run on the cropped frame as well, which is good.
However, what I really want is on the OSD display it can be combination of the inference results from both original buffer and the cropped buffer. May I know how to implement this?
- the second one is to do NvBufSurfTransform in src probe function of streammux. I tried to crop the buffer output from streammux. The surface transform I have done is similar to the implementation in gst_dsexample_transform_ip() and get_converted_mat() in dsexample. But I found there is no difference in the inference result displayed via the OSD and seems nothing have been internally cropped. Seems the dst_surface has not even been output to downstream.
Would you please help give me some advices on how to move on?
Thanks in advance.
