• Hardware Platform: Jetson AGX Xavier.
• DeepStream Version: 5.1.
Hello, I have created an app based on the code of deepstream reference app and the gst-dsexample plugin to create my custom plugin. My pipeline is as follows:
video source (resolution 1920x1080) → nvstreammux (scale to 1024x576) → nvinfer0 (pgie-detector) → nvvideoconvert (crop bottom 1024x288) → nvinfer1 (pgie-custom network) → custom_plugin (post process output of the two nvinfer) → nvdsosd → filesink
The issue I am facing is that using nvvideoconvert for cropping results in a segmentation fault (no more information is provided in the console). What I have noticed myself is that:
- by disabling
nvvideoconvert, i.e, the secondnvinferoperates on the full frame, the pipeline runs fine. - by enabling
nvvideoconvertbut disabling saving to file also runs.
Is it because thefilesinkexpects the resolution defined from thenvstreammux? In that case could I pad somehow the cropped frame with black borders to restore resolution or is there another way to workaround this issue?
One solution is to crop the video before the nvstreammux, which works, but I would rather that the first nvinfer operates on the uncropped frame.
Kindly be as detailed as possible since I am new to gstreamer. Thank you in advance!
