Trying to do nvvideoconvert before nvstreammux issue
• Hardware Platform (Jetson / GPU) Nvidia Xavier
• DeepStream Version 5.1
• TensorRT Version
• Issue Type( questions, new requirements, bugs) Issue
I’m trying to crop the camera video before input to nvstreammux.
I use deepstream-opencv-test as base.
When I run :
gst-launch-1.0 uridecodebin uri=“file:///opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_1080p_h264.mp4” ! queue ! nvvideoconvert src-crop=500:500:300:300 ! “video/x-raw(memory:NVMM),format=RGBA” ! queue ! nvstreammux0.sink_0 nvstreammux name=nvstreammux0 batch-size=1 live-source=TRUE width=500 height=500 ! queue ! nvdsosd process-mode=HW_MODE ! queue ! nvoverlaysink sync=false
All works fine. nvinver omitted for simplicity.
But When I changed the code in main() I get error :
Elements could not be linked: 0. Exiting.
ON erro check here:
if (!gst_element_link_many (nvvidconv1, caps_filter1, streammux, pgie, nvvidconv, caps_filter, nvosd, transform, sink, NULL)) {
g_printerr (“Elements could not be linked: 0. Exiting.\n”);
return -1;
At --gst-debug=4 I got
0:00:00.236314673 8061 0x555ca0f6c0 ERROR nvstreammux gstnvstreammux.c:1222:gst_nvstreammux_request_new_pad: Pad should be named ‘sink_%u’ when requesting a pad
0:00:00.236414933 8061 0x555ca0f6c0 INFO GST_ELEMENT_PADS gstutils.c:1227:gst_element_get_compatible_pad: Could not find a compatible pad to link to capsfilter1:src
How I can solve that?
Here is my code snipped:
GMainLoop *loop = NULL;
GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL,
  *nvvidconv = NULL, *nvvidconv1 = NULL, *caps_filter = NULL, *caps_filter1 = NULL,
  *nvosd = NULL;
GstElement *transform = NULL;
GstBus *bus = NULL;
guint bus_watch_id;
GstPad *osd_sink_pad = NULL;
int current_device = -1;
cudaGetDevice(&current_device);
struct cudaDeviceProp prop;
cudaGetDeviceProperties(&prop, current_device);
// Check input arguments
if (argc != 2) {
g_printerr (“Usage: %s \n”, argv[0]);
return -1;
// Standard GStreamer initialization
gst_init (&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
pgie = gst_element_factory_make (“nvinfer”, “primary-nvinference-engine”);
nvvidconv = gst_element_factory_make (“nvvideoconvert”, “nvvideo-converter”);
nvvidconv1 = gst_element_factory_make (“nvvideoconvert”, “nvvideo-converter1”);
caps_filter = gst_element_factory_make (“capsfilter”, NULL);
caps_filter1 = gst_element_factory_make (“capsfilter”, NULL);
nvosd = gst_element_factory_make (“nvdsosd”, “nv-onscreendisplay”);
// Finally render the osd output
if(prop.integrated) {
transform = gst_element_factory_make (“nvegltransform”, “nvegl-transform”);
sink = gst_element_factory_make (“nveglglessink”, “nvvideo-renderer”);
if (!pgie || !nvvidconv || !nvvidconv1 || !caps_filter || !caps_filter1 || !nvosd || !sink) {
g_printerr (“One element could not be created. Exiting.\n”);
return -1;
// Create gstreamer elements. Create Pipeline element that will form a connection of other elements
pipeline = gst_pipeline_new (“deepstream-opencv-test-pipeline”);
// Create nvstreammux instance to form batches from one or more sources.
streammux = gst_element_factory_make (“nvstreammux”, “stream-muxer”);
if (!pipeline || !streammux) {
return -1;
gst_bin_add (GST_BIN (pipeline), streammux);
GstElement *source_bin = create_source_bin (0, argv[1]);
if (!source_bin) {
g_printerr (“Failed to create source bin. Exiting.\n”);
return -1;
gst_bin_add (GST_BIN (pipeline), source_bin);
GstPad *sinkpad, *srcpad;
gchar pad_name_sink[16] = “sink_0”;
gchar pad_name_src[16] = “src”;
sinkpad = gst_element_get_request_pad (streammux, pad_name_sink);
if (!sinkpad) { g_printerr (“Streammux request sink pad failed. Exiting.\n”); return -1; }
srcpad = gst_element_get_static_pad (source_bin, pad_name_src);
if (!srcpad) { g_printerr (“Failed to get src pad of source bin. Exiting.\n”); return -1; }
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) { g_printerr (“Failed to link source bin to stream muxer. Exiting.\n”); return -1; }
gst_object_unref (srcpad);
gst_object_unref (sinkpad);
if(!transform && prop.integrated) {
g_printerr (“One tegra element could not be created. Exiting.\n”);
return -1;
g_object_set (G_OBJECT (streammux), “width”, MUXER_OUTPUT_WIDTH, “height”,
MUXER_OUTPUT_HEIGHT, “batch-size”, 1, “batched-push-timeout”, MUXER_BATCH_TIMEOUT_USEC, NULL);
// Set all the necessary properties of the nvinfer element, the necessary ones are :
g_object_set (G_OBJECT (pgie), “config-file-path”, “dsopencvtest_pgie_config.txt”, NULL);
if(!prop.integrated) {
// Set properties of the nvvideoconvert element requires unified cuda memory for opencv blurring on CPU
g_object_set (G_OBJECT (nvvidconv), “nvbuf-memory-type”, 1, NULL);
g_object_set (G_OBJECT (nvvidconv1), “nvbuf-memory-type”, 1, NULL);
// Set properties of the caps_filter element
GstCaps *caps = gst_caps_new_simple (“video/x-raw”, “format”, G_TYPE_STRING, “RGBA”, NULL);
GstCapsFeatures *feature = gst_caps_features_new (MEMORY_FEATURES, NULL);
gst_caps_set_features (caps, 0, feature);
g_object_set (G_OBJECT (caps_filter), “caps”, caps, NULL);
GstCaps *caps1 = gst_caps_from_string(“video/x-raw(memory:NVMM),format=RGBA,width=500,height=500”);
GstCapsFeatures *feature1 = gst_caps_features_new (MEMORY_FEATURES, NULL);
gst_caps_set_features (caps1, 0, feature1);
g_object_set (G_OBJECT (caps_filter1), “caps”, caps1, NULL);
// Set properties of the sink element
g_object_set (G_OBJECT (sink), “sync”, FALSE, NULL);
// we add a message handler
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
// Set up the pipeline we add all elements into the pipeline
gst_bin_add_many (GST_BIN (pipeline), nvvidconv1, caps_filter1, pgie, nvvidconv, caps_filter, nvosd, NULL);
gst_bin_add_many (GST_BIN (pipeline), transform, sink, NULL);
else {
gst_bin_add_many (GST_BIN (pipeline), sink, NULL);
// we link the elements together file-source → h264-parser → nvh264-decoder → nvinfer → nvvidconv → nvosd → video-renderer
return -1;
else {
streammux, pgie, nvvidconv, caps_filter, nvosd, sink, NULL)) {
g_printerr (“Elements could not be linked: 2. Exiting.\n”);
return -1;
// Lets add probe to get informed of the meta data generated, we add probe to
// the sink pad of the osd element, since by that time, the buffer would have had got all the metadata.
osd_sink_pad = gst_element_get_static_pad (nvosd, “sink”);
if (!osd_sink_pad)
g_print (“Unable to get sink pad\n”);
else
gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER, osd_sink_pad_buffer_probe, NULL, NULL);
gst_object_unref (osd_sink_pad);
// Set the pipeline to “playing” state
g_print (“Now playing: %s\n”, argv[1]);
gst_element_set_state (pipeline, GST_STATE_PLAYING);
// Wait till pipeline encounters an error or EOS
g_print (“Running…\n”);
g_main_loop_run (loop);
// Out of the main loop, clean up nicely
g_print (“Returned, stopping playback\n”);
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print (“Deleting pipeline\n”);
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
What I made wrong?
I found a solution by editing deepstream_source_bin.c in create_uridecode_src_bin:
bin->rotateresize = gst_element_factory_make (“rotateresize”, “rotate_elem”);
if (!bin->rotateresize) {
NVGSTDS_ERR_MSG_V (“Could not create element ‘rotate_elem’”);
goto done;
caps_src = gst_caps_from_string(“video/x-raw(memory:NVMM),format=NV12”);
g_object_set(G_OBJECT(bin->cap_filter), “caps”, caps_src, NULL);
caps = gst_caps_from_string(“video/x-raw(memory:NVMM),format=RGBA,width=500,height=500”);
bin->cap_filter1 = gst_element_factory_make (NVDS_ELEM_CAPS_FILTER, “src_cap_filter_nvvidconv”);
if (!bin->cap_filter1)
NVGSTDS_ERR_MSG_V (“Could not create ‘queue’”);
goto done;
g_object_set (G_OBJECT (bin->nvvidconv), “src-crop”, “500:500:1800:1800”, NULL);
g_object_set (G_OBJECT (bin->nvvidconv), “dest-crop”, “0:0:500:500”, FALSE, NULL);
g_object_set(G_OBJECT(bin->cap_filter1), “caps”, caps, NULL);
gst_caps_unref(caps);
g_object_set_data (G_OBJECT (bin->cap_filter), SRC_CONFIG_KEY, config);
gst_bin_add_many (GST_BIN (bin->bin), bin->src_elem, bin->cap_filter,
bin->nvvidconv, bin->cap_filter1, bin->rotateresize, NULL);
NVGSTDS_BIN_ADD_GHOST_PAD (bin->bin, bin->rotateresize, “src”);
bin->fakesink = gst_element_factory_make (“fakesink”, “src_fakesink”);
if (!bin->fakesink) {
NVGSTDS_ERR_MSG_V (“Could not create ‘src_fakesink’”);
goto done;
bin->fakesink_queue = gst_element_factory_make (“queue”, “fakequeue”);
if (!bin->fakesink_queue) {
NVGSTDS_ERR_MSG_V (“Could not create ‘fakequeue’”);
goto done;
bin->tee = gst_element_factory_make (“tee”, NULL);
if (!bin->tee) {
NVGSTDS_ERR_MSG_V (“Could not create ‘tee’”);
goto done;
gst_bin_add_many (GST_BIN (bin->bin), bin->fakesink, bin->tee, bin->fakesink_queue, NULL);
NVGSTDS_LINK_ELEMENT (bin->fakesink_queue, bin->fakesink);
if (config->dewarper_config.enable) {
gst_bin_add_many (GST_BIN (bin->bin), bin->dewarper_bin.bin, NULL);
NVGSTDS_LINK_ELEMENT (bin->tee, bin->dewarper_bin.bin);
NVGSTDS_LINK_ELEMENT (bin->dewarper_bin.bin, bin->cap_filter);
} else {
link_element_to_tee_src_pad (bin->tee, bin->cap_filter);
NVGSTDS_LINK_ELEMENT (bin->cap_filter, bin->nvvidconv);
NVGSTDS_LINK_ELEMENT (bin->nvvidconv, bin->cap_filter1);
NVGSTDS_LINK_ELEMENT (bin->cap_filter1, bin->rotateresize);
And that works fine!
Glad to know issue resolved, thanks for the update.
Hi, could you please share the complete solution? I’m having a similar problem trying to extend deepstream-test3 to work with multiple clips from the same uridecoder_bin, but still with no success
