wlzkobe:
output
0:00:55.523144927 e[334m18951e[00m 0x7ffe9c0051e0 e[37mDEBUG e[00m e[00;01;33m GST_CLOCK gstclock.c:1046:gst_clock_get_internal_time:e[00m internal time 198:55:10.695785135
0:00:55.523193026 e[334m18951e[00m 0x7ffe9c0051e0 e[37mDEBUG e[00m e[00;01;33m GST_CLOCK gstclock.c:1091:gst_clock_get_time:e[00m adjusted time 198:55:10.695785135
0:00:55.523231230 e[334m18951e[00m 0x7ffe9c0051e0 e[37mDEBUG e[00m e[00m nvstreammux gstnvstreammux.c:2196:gst_nvstreammux_src_push_loop:e[00m Pushing buffer 0x7ffea0058350, batch size 1, PTS 0:00:51.089233330
0:00:55.523266556 e[334m18951e[00m 0x7ffe9c0051e0 e[37mDEBUG e[00m e[00m nvstreammux gstnvstreammux.c:2218:gst_nvstreammux_src_push_loop:e[00m STREAMMUX OUT BUFFER attached timestamp 0:00:51.089233330
0:00:55.523387171 e[334m18951e[00m 0x7ffe9c0051e0 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4320:gst_pad_chain_data_unchecked:<core_bin0:sink>e[00m calling chainfunction &gst_proxy_pad_chain_default with buffer buffer: 0x7ffea0058350, pts 0:00:51.089233330, dts 99:99:99.999999999, dur 99:99:99.999999999, size 64, offset none, offset_end none, flags 0x0
0:00:55.523447248 e[334m18951e[00m 0x7ffe9c0051e0 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4320:gst_pad_chain_data_unchecked:<core_queue0:sink>e[00m calling chainfunction &gst_queue_chain with buffer buffer: 0x7ffea0058350, pts 0:00:51.089233330, dts 99:99:99.999999999, dur 99:99:99.999999999, size 64, offset none, offset_end none, flags 0x0
0:00:55.523493579 e[334m18951e[00m 0x7ffe9c0051e0 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4326:gst_pad_chain_data_unchecked:<core_queue0:sink>e[00m called chainfunction &gst_queue_chain with buffer 0x7ffea0058350, returned ok
0:00:55.523506800 e[334m18951e[00m 0x7fff8c4b4770 e[37mDEBUG e[00m e[00m queue_dataflow gstqueue.c:1528:gst_queue_loop:<core_queue0>e[00m queue is not empty
0:00:55.523521436 e[334m18951e[00m 0x7ffe9c0051e0 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4326:gst_pad_chain_data_unchecked:<core_bin0:sink>e[00m called chainfunction &gst_proxy_pad_chain_default with buffer 0x7ffea0058350, returned ok
0:00:55.523572879 e[334m18951e[00m 0x7fff8c4b4770 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4320:gst_pad_chain_data_unchecked:<core_infer0:sink>e[00m calling chainfunction &gst_base_transform_chain with buffer buffer: 0x7ffea0058350, pts 0:00:51.089233330, dts 99:99:99.999999999, dur 99:99:99.999999999, size 64, offset none, offset_end none, flags 0x0
0:00:55.523667920 e[334m18951e[00m 0x7ffe9c0051e0 e[37mDEBUG e[00m e[00;01;42m GST_BUFFER gstbuffer.c:2202:gst_buffer_add_meta:e[00m alloc metadata 0x7ffea0099308 (NvDsMeta) of size 72
0:00:55.523891472 e[334m18951e[00m 0x7fff8c4b4770 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4326:gst_pad_chain_data_unchecked:<core_infer0:sink>e[00m called chainfunction &gst_base_transform_chain with buffer 0x7ffea0058350, returned ok
0:00:55.523921128 e[334m18951e[00m 0x7fff8c4b4770 e[37mDEBUG e[00m e[00m queue_dataflow gstqueue.c:1516:gst_queue_loop:<core_queue0>e[00m queue is empty
0:00:55.524030815 e[334m18951e[00m 0x7ffe84002550 e[37mDEBUG e[00m e[00;01;42m GST_BUFFER gstbuffer.c:1375:gst_buffer_is_memory_range_writable:e[00m idx 0, length -1
0:00:55.531935725 e[334m18951e[00m 0x7fff8c4b4720 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4320:gst_pad_chain_data_unchecked:<core_tracker0:sink>e[00m calling chainfunction &gst_base_transform_chain with buffer buffer: 0x7ffea0058350, pts 0:00:51.089233330, dts 99:99:99.999999999, dur 99:99:99.999999999, size 64, offset none, offset_end none, flags 0x0
0:00:55.532099146 e[334m18951e[00m 0x7fff8c4b4720 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4326:gst_pad_chain_data_unchecked:<core_tracker0:sink>e[00m called chainfunction &gst_base_transform_chain with buffer 0x7ffea0058350, returned ok
0:00:55.532261851 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4320:gst_pad_chain_data_unchecked:src:proxypad4 e[00m calling chainfunction &gst_proxy_pad_chain_default with buffer buffer: 0x7ffea0058350, pts 0:00:51.089233330, dts 99:99:99.999999999, dur 99:99:99.999999999, size 64, offset none, offset_end none, flags 0x0
0:00:55.532313436 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4320:gst_pad_chain_data_unchecked:iva-streamdemux:sink e[00m calling chainfunction &gst_nvstreamdemux_sink_chain_cuda_batch with buffer buffer: 0x7ffea0058350, pts 0:00:51.089233330, dts 99:99:99.999999999, dur 99:99:99.999999999, size 64, offset none, offset_end none, flags 0x0
0:00:55.532379454 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;34m GST_CAPS gstpad.c:2705:gst_pad_has_current_caps:iva-streamdemux:src_0 e[00m check current pad caps video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)25/1, batch-size=(int)1, num-surfaces-per-frame=(int)1
0:00:55.532405557 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;42m GST_BUFFER gstbuffer.c:1148:gst_buffer_get_memory_range:e[00m idx 0, length 1
0:00:55.532433388 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;34m GST_MEMORY gstmemory.c:139:gst_memory_init:e[00m new memory 0x7ffea03edba0, maxsize:64 offset:0 size:64
0:00:55.532491196 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;42m GST_BUFFER gstbuffer.c:2202:gst_buffer_add_meta:e[00m alloc metadata 0x7ffe9002ed88 (NvDsMeta) of size 72
0:00:55.532536742 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4320:gst_pad_chain_data_unchecked:<sink_bin0:sink>e[00m calling chainfunction &gst_proxy_pad_chain_default with buffer buffer: 0x7ffea005e030, pts 0:00:50.848190110, dts 99:99:99.999999999, dur 99:99:99.999999999, size 64, offset none, offset_end none, flags 0x0
0:00:55.532565869 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4320:gst_pad_chain_data_unchecked:<sink_queue0:sink>e[00m calling chainfunction &gst_queue_chain with buffer buffer: 0x7ffea005e030, pts 0:00:50.848190110, dts 99:99:99.999999999, dur 99:99:99.999999999, size 64, offset none, offset_end none, flags 0x0
0:00:55.532603749 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;34m GST_MEMORY gstmemory.c:88:_gst_memory_free:e[00m free memory 0x7ffea03edba0
0:00:55.532628112 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4326:gst_pad_chain_data_unchecked:<sink_queue0:sink>e[00m called chainfunction &gst_queue_chain with buffer 0x7ffea005e030, returned error
0:00:55.532649542 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4326:gst_pad_chain_data_unchecked:<sink_bin0:sink>e[00m called chainfunction &gst_proxy_pad_chain_default with buffer 0x7ffea005e030, returned error
0:00:55.532670296 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;42m GST_BUFFER gstbuffer.c:2384:gst_buffer_foreach_meta:e[00m remove metadata 0x7ffe9002ec68 (NvDsMeta)
0:00:55.532710536 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00m nvdspool gstnvdsbufferpool.c:492:gst_nvds_buffer_pool_release_buffer:e[00m release_buffer
0:00:55.532729846 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;42m GST_BUFFER gstbuffer.c:1375:gst_buffer_is_memory_range_writable:e[00m idx 0, length -1
0:00:55.532749866 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;42m GST_BUFFER gstbuffer.c:1375:gst_buffer_is_memory_range_writable:e[00m idx 0, length -1
0:00:55.532770354 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4326:gst_pad_chain_data_unchecked:iva-streamdemux:sink e[00m called chainfunction &gst_nvstreamdemux_sink_chain_cuda_batch with buffer 0x7ffea0058350, returned error
0:00:55.532792235 e[334m18951e[00m 0x7fff8c5c10a0 e[37mDEBUG e[00m e[00;01;35m GST_SCHEDULING gstpad.c:4326:gst_pad_chain_data_unchecked:src:proxypad4 e[00m called chainfunction &gst_proxy_pad_chain_default with buffer 0x7ffea0058350, returned error
