It does not work to change the item in the configure file, such as source30_1080p_dec_infer-resnet_tiled_display_int8_now.txt. Where is the parameter of the border color of a frame?
[primary-gie] enable=1 gpu-id=0 #Modify as necessary model-engine-file=/opt/nvidia/deepstream/deepstream-5.1/samples/models/resnet18/resnet18_2.engineer batch-size=1 #Required by the app for OSD, not a plugin property bbox-border-color0=1;0;0;1 bbox-border-color1=0;1;1;1 bbox-border-color2=0;0;1;1 bbox-border-color3=0;1;0;1 gie-unique-id=1 config-file=config_infer_primary_resnet18_20210806.txt
I hope to change the frame border color according to the classifying result. For example, the frame border is red if this frame is belong to class 1. How to set this?
