Dear all,
I am learning OpenACC with an example: compute pi using fractional method, and do it multiple times. So there are two for-loops can be accelerated.
I tried 1) to write everything in the same file
pi.cpp
#include <iostream>
#include <chrono>
#pragma acc routine worker
double fracpi(long N);
using namespace std;
int main() {
long i, j, ntrial, N;
double pi[10];
N = 1000000000;
ntrial = 10;
cout << "Pi Computing Test" << endl;
auto t0 = std::chrono::high_resolution_clock::now();
#pragma acc parallel
#pragma acc loop gang
for (j = 0; j < ntrial; j++) {
pi[j] = fracpi(N);
auto t1 = std::chrono::high_resolution_clock::now();
for (i = 0; i < ntrial; i++) {
cout << "Pi: " << pi[i] << endl;
cout << "Loop OpenACC Elapse time: " << std::chrono::duration_cast<std::chrono::milliseconds>(t1 - t0).count()
<< endl;
return 0;
double fracpi(long N) {
long i;
double piN;
double pi;
piN = 0.0;
#pragma acc loop worker reduction(+:piN)
for (i = 0; i < N; i++) {
double t = (double) ((i + 0.05) / N);
piN += 4.0 / (1.0 + t * t);
pi = piN / N;
return pi;
and compiled with command
pgc++ -acc -std=c++11 -Minfo=all -Mcuda=cuda8.0 -ta=tesla,cuda8.0 -mp pi.cpp -o pi.x
which can be compiled successively with message
main:
25, Generating implicit copyout(pi[:])
Accelerator kernel generated
Generating Tesla code
25, #pragma acc loop gang /* blockIdx.x /
fracpi(long):
39, Generating Tesla code
47, #pragma acc loop vector, worker / threadIdx.x threadIdx.y */
39, Generating acc routine worker
reduction in routine disables compute capability 2.0 kernel
47, Loop is parallelizable
However, I tried to 2) put main output in
main.cpp
#include <iostream>
#include <chrono>
#include "compute.h"
int main() {
double pi[10];
N = 1000000000;
ntrial = 10;
pi[j] = fracpi(N);
<< endl;
return 0;
and function in
compute.h
compute.cpp
long i;
double piN;
double pi;
piN = 0.0;
pi = piN / N;
return pi;
pgc++ -acc -std=c++11 -Minfo=all -Mcuda=cuda8.0 -ta=tesla,cuda8.0 -mp main.cpp compute.cpp -o pi.x
, it does not work. The error message is
compute.cpp:
fracpi(long):
7, Generating Tesla code
15, #pragma acc loop vector, worker /* threadIdx.x threadIdx.y /
7, Generating acc routine worker
15, Loop is parallelizable
main.cpp:
main:
19, Generating implicit copyout(pi[:])
19, #pragma acc loop gang / blockIdx.x */
nvlink error : Undefined reference to ‘_Z6fracpil’ in ‘main.o’
pgacclnk: child process exit status 2: pgnvd
So would you please help me in
A) How to compile 2) properly?
B) When I increase my N to N = 10,000,000,000, and run ./pi.x, an error happens:
Pi Computing Test
Message from syslogd@czgpu2 at Apr 19 19:31:17 …
kernel:NMI watchdog: BUG: soft lockup - CPU#4 stuck for 23s! [a.out:12334]Accelerator Kernel Timing data
/usr/include/c++/4.8.5/iostream
main NVIDIA devicenum=0
time(us): 0
25: data region reached 1 time
25: compute region reached 1 time
25: kernel launched 1 time
grid: [10] block: [32x8]
device time(us): total=0 max=0 min=0 avg=0
. It seems that I did not allocate my grid/block/thread properly. would you please give me some advices in allocating grid/block/thread?
Thank you very much!
Sincerely,
Lin
