Dear all:
1: With JetPack4.6_R32.6.1,Jetson Xavier NX with custom board, we connect mcp2515 to SOM,
2: change tegra_defconfig
- CONFIG_CAN_MCP251X=y
- CONFIG_CAN=y
3: configure device-tree in tegra194-p3668-common.dtsi
can_clock: can_clock {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <8000000>;
clock-accuracy = <100>;
spi@3210000{ /* SPI1 in 40 pin conn */
status = "okay";
spi@0 { /* chip select 0 */
compatible = "microchip,mcp2515";
reg = <0x0>;
spi-max-frequency = <10000000>;
interrupt-parent = <&tegra_main_gpio>;
interrupts = <TEGRA194_MAIN_GPIO(Z, 6) 0x0>;
clocks = <&can_clock>;
controller-data {
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x10>;
nvidia,tx-clk-tap-delay = <0x0>;
spi@1 { /* chip select 1 */
compatible = "tegra-spidev";
reg = <0x1>;
spi-max-frequency = <50000000>;
controller-data {
4: dmesg.log:
[ 2.823403] mcp251x spi0.0: MCP251x didn't enter in conf mode after reset
[ 2.823654] mcp251x spi0.0: Probe failed, err=16
[ 2.823836] mcp251x: probe of spi0.0 failed with error -16
[ 2.823942] mcp251x: probe of spi0.1 failed with error -2
5: 4 pin (spi0_sck, spi0_MISO, spio_MOSI. spi0_CS0 voltage is normal)
I guess, incorrect configuration of device-tree may is the key. So could you have some suggestions?
Thank you very much!
