hi,
I want to generate a int8 calibrator for my own ai algorithm. According to sampleINT8
- Apply the patch. The patch can be applied by going to the root directory of the Caffe source tree and applying the patch with the command:
patch -p1 < int8_caffe.patch
then, I run the following commands:
make clean
make -j12
there come up an error:
CXX src/caffe/layers/multinomial_logistic_loss_layer.cpp
src/caffe/layers/data_layer.cpp: In member function ‘virtual void caffe::DataLayer::load_batch(caffe::Batch*)’:
src/caffe/layers/data_layer.cpp:140:18: error: ‘top_shape’ was not declared in this scope
int s[4] = { top_shape[0], top_shape[1], top_shape[2], top_shape[3] };
src/caffe/layers/data_layer.cpp:142:12: error: ‘top_data’ was not declared in this scope
fwrite(top_data, sizeof(float), top_shape[0]*top_shape[1]*top_shape[2]*top_shape[3], file);
src/caffe/layers/data_layer.cpp:143:13: error: ‘top_label’ was not declared in this scope
fwrite(&top_label[0], sizeof(int), top_shape[0], file);
Makefile:585: recipe for target ‘.build_release/src/caffe/layers/data_layer.o’ failed
make: *** [.build_release/src/caffe/layers/data_layer.o] Error 1
make: *** Waiting for unfinished jobs…
How to solve this problom?
