Description
I try to convert an caffe model to ICudaEngine and do the tensort inference.
at begining,I created network definition with flag:trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH, the engine is created and the result of inference is normally(with api: context.execute_async_v2()). then I add a calibrator to create an Int8 model. It still works well.
since using flag:trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH cannot do batch inference(our caffe model without dynamic shape), I try to create network definition with flag:trt.NetworkDefinitionCreationFlag.EXPLICIT_PRECISION. it also works well and can do batch inference(with api execute_async). But when I set a calibrator to create an int8 model,i get the error:
../builder/cudnnBuilderWeightConverters.cpp:163: std::vector nvinfer1::cudnn::makeConvDeconvInt8Weights(nvinfer1::ConvolutionParameters&, const nvinfer1::rt::EngineTensor&, const nvinfer1::rt::EngineTensor&, float, bool, bool): Assertion `sI.count() == 1’ failed.
what’s that meaning? and what case this error?
Environment
TensorRT Version: 7.0.0
GPU Type: gtx1070
Nvidia Driver Version: 455.45.01
CUDA Version: 11.1
CUDNN Version: 7.6
Operating System + Version: ubuntu 18.04
Python Version (if applicable): 3.6.9
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag): nvcr.io/nvidia/deepstream:5.0.1-20.09-triton
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
