Description
A clear and concise description of the bug or issue.
Environment
TensorRT Version: 5.1.5.0
GPU Type: RTX-2080
Nvidia Driver Version: 450.102.04
CUDA Version: 10.1
CUDNN Version: 7.5
Operating System + Version: Ubuntu 18.04
Python Version (if applicable): 3.6
TensorFlow Version (if applicable):
PyTorch Version (if applicable): 1.4
Baremetal or Container (if container which image + tag):
Hello, I managed successfully run and and build an int8 engine for my custom model, however when I tried to increase the batch size, the calibration process fails with the following error:
[TensorRT] ERROR: engine.cpp (572) - Cuda Error in commonEmitTensor: 1 (invalid argument)
[TensorRT] ERROR: Failure while trying to emit debug blob.
[TensorRT] ERROR: cuda/caskConvolutionLayer.cpp (355) - Cuda Error in execute: 1 (invalid argument)
It keeps reproducing itself for every injected batch.
My code below:
class EntropyCalibrator(trt.IInt8EntropyCalibrator2):
def init(self, cfg, seq_list, cache_file):
# Whenever you specify a custom constructor for a TensorRT class,
# MUST call the constructor of the parent explicitly.
trt.IInt8EntropyCalibrator2.init(self)
self.batch_size = 3
self.batch_shape = (self.batch_size, IMG_CH, IMG_H, IMG_W)
self.cache_file = cache_file
self.cfg = cfg
self.seq_list = seq_list
self.frames_per_seq = list()
self.delution_factor = cfg['delution_factor']
for seq in seq_list:
lidar_list = sorted([cfg['dataset_dir'] + seq + '/LIDAR_TOP/data/' + f.strip()
for f in open(cfg['dataset_dir'] + seq + '/LIDAR_TOP/samples.txt', 'r').readlines()])
self.frames_per_seq.append(len(lidar_list))
self.current_seq = 0
self.counter = 0 # for keeping track of how many files we have read
self.device_input = cuda.mem_alloc(trt.volume(self.batch_shape) * trt.float32.itemsize)
Inside the get_batch I use the following code:
depthnet_input_batch = np.zeros((self.batch_size, IMG_H * IMG_W * IMG_CH), dtype=np.float32)
for i, cam_data in enumerate(cameras_data):
img = cam_data['img_data'].data.cpu().numpy()
img = img.squeeze()
img = img.transpose((2, 0, 1))
img = img.ravel()
img = np.ascontiguousarray(img)
depthnet_input_batch[i, :] = img
depthnet_input_batch = np.asarray(depthnet_input_batch[:self.batch_size]).ravel()
cuda.memcpy_htod(self.device_input, depthnet_input_batch)
