How to deepstream custom filter
I want to customize the nvmsgconv plug-in of deepstream, what should I modify?
I don’t want the name to overlap with the existing plug-in
• DeepStream Version
• TensorRT Version
• Hardware Platform : Jetson Nano
• DeepStream Version : 5.1
• JetPack Version : 4.5.1
• TensorRT Version
• Issue Type : questions
• How to reproduce the issue : how to custom (nvmsgconv plug-in of deepstream)
• Requirement details : I want to customize the nvmsgconv plug-in of deepstream, what should I modify? I don’t want the name to overlap with the existing plug-in
Please refer below for customize.
Gst-nvmsgconv — DeepStream 6.0.1 Release documentation (nvidia.com)
Thank you for your answer.
However, I would like to make a new gstreamer filter by customizing the existing plug-in instead of modifying the existing plug-in.
When implementing the filter by modifying only the name of the plug-in, there is a problem that the result of “gst-inspect-1.0” is registered in the black list, so I leave a question again.
Please refer gstreamer document if you have gstreamer plugin issue.
https://gstreamer.freedesktop.org/documentation/?gi-language=c
