Deepstream
• DeepStream Version
• TensorRT Version
Hi i want to use rtsp that contain (&) on it so how can i use this rtsp in deepstream binding
I have a correct pipeline and it works witout & but when i change it to that rtsp
deepstream thinks it’s a different thing and seprate it from rtsp so i got rtsp bad request error
How can i fix it?
• TensorRT Version
Deepstream 7
GPU T4,A5000
driver version : 525.183.01
trt : 8.6.1.6.1+cuda12.0
cuda : 12.2
my rtsp uri contain ampersand(&) how can i use it in nvurisrcbin when i am working with deepstream binding python . more detail exist in my first message
could you share the whole log including that “rtsp bad request error”? if testing the rtsp url with (&), can the following cmd work well?
gst-launch-1.0 -v nvurisrcbin uri=rtsp://xxx ! fakesink
nope i have the same error and i even use this command multiple times without (“”) and with (“”) too
altough ffmplay work corectly by using (“”) unlike deepstream
can the following cmds work? please refer to this topic.
gst-launch-1.0 rtspsrc location=rtsp://address ! fakesink
gst-launch-1.0 rtspsrc location='rtsp://address'  ! fakesink
i have gotten same error but i found the problem it works in gstreamer 2.22.6 pls update your installation guide for ubuntu 22
Thanks for the update!
  1. the latest gstreamer version is 1.24.6 . please refer to the link. what do you mean about “gstreamer 2.22.6” ?.
  2. about “it works”, how did you test? could you share the test pipeline? Thanks!
1.22.6*
i install gsttreamer version 1.22.6 and it works
my pipeline was your last bash code
