Deepstream-server Issue with RTSP (nvurisrcbin or nvmultiurisrcbin issue)
• DeepStream Version 6.4
• TensorRT Version
Problem:
  • Deepstream-server fails to read RTSP stream after is launched without a video file.
  • It keeps trying to reconnect to the RTSP feed but doesn’t succeed.
  • Providing a video file after launching the server enables both the RTSP and video processing, displaying FPS for both sources.
To reproduce the issue
gst-launch-1.0 nvmultiurisrcbin \
port=9000 ip-address=localhost \
batched-push-timeout=33333 max-batch-size=10 \
drop-pipeline-eos=1  rtsp-reconnect-interval=1  live-source=1 width=1920 height=1080 \
! nvmultistreamtiler ! nveglglessink
This will run the app without any video, it will wait for rtsp or video request. First post RTSP, it will keep try to reconnect , until you post a video file , then it will appear the window for both the RTSP and the file.
To conclude, the deepstream-server can’t read the rtsp when it is running unless you post a video file or you post the rtsp during initialization. Otherwise, it won’t read the RTSP
Notice:
This issue is only occurred in Deepstream 6.4
You mean it was good on the previous version?
In 6.3 , yes. Please try to reproduce it in 6.4 then check it in 6.3
Could you attach the steps you verified that on DeepStream 6.3 in detail? I have tried that with DeepStream 6.3, but it will report Error 404: Not Found when sending the source to the server.
What source are you sending? And what is the route that you are using to add source?
I think you are applying the wrong route for adding in DS 6.3, please use
http://localhost:9000/stream/add
in DS6.4 the route is
http://localhost:9000/api/v1/stream/add
1- run
2- in DS 6.3 to add camera
  curl -XPOST 'http://localhost:9000/stream/add' -d '{
    "key": "sensor",
    "value": {
        "camera_id": "uniqueSensorID1",
        "camera_name": "front_door",
        "camera_url": "file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4",
        "change": "camera_add",
        "metadata": {
            "resolution": "1920 x1080",
            "codec": "h264",
            "framerate": 30
    "headers": {
        "source": "vst",
        "created_at": "2021-06-01T14:34:13.417Z"
Please use rtsp in
camera_url
instead of file://
for more information read the README file in
/opt/nvidia/deepstream/deepstream-6.3/sources/apps/sample_apps/deepstream-server/README
Thanks. We’ll analyze that as soon as possible.
I upgraded the GStreamer version in DS6.3 from 1.16 to 1.20 (the same version used in DS 6.4). The problem occurred after the upgrade. I believe the issue is related to GStreamer 1.20
OK. Thanks for that information. We’ll analyze that further.
Could you just try to set the async=false to the sink plugin currently?
