• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.1 docker
gst-launch-1.0 nvmultiurisrcbin port=9999 ip-address=localhost batched-push-timeout=33333 max-batch-size=10 drop-pipeline-eos=1 live-source=1 width=2560 height=1440 ! videoconvert ! nvv4l2h265enc bitrate=3000000 ! rtspclientsink location=rtsp://0.0.0.0:8558/1111
when add a rtsp stream , will error
Setting pipeline to PAUSED ...
Failed to query video capabilities: Invalid argument
Civetweb version: v1.16
Server running at port: 9999
Progress: (open) Opening Stream
Pipeline is PREROLLED ...
Prerolled, waiting for progress to finish...
Progress: (connect) Connecting to rtsp://0.0.0.0:8558/1111
Progress: (open) Retrieving server options
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending RECORD request
Redistribute latency...
uri:/api/v1/stream/add
method:POST
Progress: (open) Open canceled
Progress: (request) Sending PLAY request
Progress: (connect) Connecting to rtsp://192.168.3.227:8558/card/4
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (request) SETUP stream 1
Progress: (request) Sent PLAY request
Encode Latency = 182.383057
Progress: (record) Sending server stream info
ERROR: from element /GstPipeline:pipeline0/GstRTSPClientSink:rtspclientsink0: Could not get/set settings from/on resource.
Additional debug info:
../gst/rtsp-sink/gstrtspclientsink.c(4258): gst_rtsp_client_sink_setup_streams (): /GstPipeline:pipeline0/GstRTSPClientSink:rtspclientsink0:
Could not setup transport.
Execution ended after 0:00:07.977187391
Setting pipeline to NULL ...
Stopping the server..!!
Stopped the server..!!
Freeing pipeline ...
Please put nvmultistreamtiler after nvmultiurisrcbin to convert the batched video(s) to normal single video.
“videoconvert” is the GStreamer open source plugin videoconvert which only supports video in CPU buffers. But the video in the DeepStream plugins are in GPU hardware buffers. You can’t use non-DeepStream plugin directly with DeepStream plugins. All DeepStream plugins are listed in GStreamer Plugin Overview — DeepStream documentation .
Please read the document and understand the DeepStream plugins’ function before you use them.
The possible pipeline may look like
gst-launch-1.0 nvmultiurisrcbin port=9999 ip-address=localhost batched-push-timeout=33333 max-batch-size=10 drop-pipeline-eos=1 live-source=1 width=2560 height=1440 ! nvmultistreamtiler columns=5 rows=2 width=2560 height=1440 ! nvvideoconvert ! nvv4l2h265enc bitrate=3000000 ! rtspclientsink location=rtsp://0.0.0.0:8558/1111
still error
method:POST
Encode Latency = 11.345947
Execution ended after 0:00:08.627749134
Please check your RTSP server.
the stream can open with VLC
Currently the nvmultiurisrcbin does not support work with “gst-launch-1.0” without stream, you need to start the “gst-launch” pipeline with at least one source stream.
Seems there is a RTSP server rtsp://0.0.0.0:8558/1111. Please check this server.
yingliu
December 30, 2024, 10:42am
9
system
Closed
January 13, 2025, 10:42am
10
