• Hardware Platform (Jetson / GPU) gpu • DeepStream Version 7 • JetPack Version (valid for Jetson only) • TensorRT Version i install it using deepstream 7 instalation guide • NVIDIA GPU Driver Version (valid for GPU only) 535 • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Hi
I have a rtsp server and i want to use that instead of gstreamer server that exist in your deepstream binding examples
I tried gstreamer server and it works but i have another server
You can think of it as i have a twitch link (rtsp not rtmp) and i want to restream there what howud i add to my pipeline instead of creating gstreamer server
Should I use rtspclientsink or not? How?
Thank you for taking the time to read this long message.
Ty for responding
What about pipeline is it correct?i tried this but didn’t work correctly
Nvurisrcbin-> streammux-> pgie->tracker->demux - - for every camera - - > queue->nvvideoconvert->nvosd->nvvideoconvert->encoder->h264parse->rtspclientsink
I even tried :
Nvurisrcbin-> streammux-> pgie->tracker->demux - - for every camera - - > nvvideoconvert->caps->encoder->rtppay(rth264…)->rtspclientsink
Please use the following pipeline to verify that your server is working properly. If the pipeline can not working properly, there may be a problem with your server, or it is not compatible with Gstreamer.
Ty for responding
Your answer has a lot of work in my side forexample build another python code with ncurisrcbin and other things
I think i now have 2 question
Is there any command to do this?like your last response cuz i only use python
don’t you know the exact pipeline for my
situation?
I’m ok with urisrcbin i’m talking about which pipeline should i use for my problem
For example in my last reply i said my pipeline was it correct or not? Where should i focus to fix it?
Because you need to check which plugin causes the problem, the fastest way is to to use gst-launch-1.0 command. I have attached some pipeline command and how to use the nvurisrcbin in the gst-launch-1.0 command.
Another way you can address the problem is by modifying your own code to add and replace plugins and attach the log.
