• Hardware Platform (Jetson / GPU) Jetson orin nx 8g
• DeepStream Version 7.0
• JetPack Version (valid for Jetson only) 6.0 L4T 36.3.0
• Issue Type( questions, new requirements, bugs) bugs
I have never encountered issues when using nvurisrcbin
to read RTSP streams from a camera. However, I have noticed that this plugin occasionally malfunctions when reading RTSP streams forwarded by a GStreamer RTSP server. Specifically, it repeatedly triggers reconnection attempts but fails to connect, even though the RTSP stream can be successfully opened with VLC, PotPlayer, or FFplay.
Unfortunately, this issue does not occur consistently; it only happens intermittently, so I’m not sure if you will be able to reproduce it.
I have constructed two simple pipelines to test this bug. The first pipeline uses nvurisrcbin
to loop-read a file and forward it via nvrtspoutsinkbin
sudo gst-launch-1.0 nvurisrcbin uri=file:///home/nvidia/tunnel.mp4 file-loop=1 ! nvrtspoutsinkbin rtsp-port=10000
The second pipeline is:
sudo gst-launch-1.0 nvurisrcbin uri=rtsp://localhost:10000/ds-test rtsp-reconnect-interval=5 ! nvrtspoutsinkbin
Test Video:
tunnel.zip (11.3 MB)
Output Log:
logs.txt (43.4 KB)
