Multistream Pipeline to enable streams which got disconnected without disrupting the operation of other streams
**• Hardware Platform (Jetson / GPU): Nvidia jetson nano Developer kit
**• DeepStream Version: 6.0.1
**• JetPack Version (valid for Jetson only): L4T 32.7.4
**• TensorRT Version: 8.2.1.9
I am currently working on a multistream pipeline using the sample python code from deepstream-test3`. My goal is to build a pipeline that allows an arbitrary number of input streams, with the capability to attempt to enable streams which got disconnected (single reconnect attempt after every minute )without disrupting the operation of other streams.
Currently if a stream gets disconnected it will try the reconnect arrempts but other streams also get stuck in the process.
Thanks in advance.
Are you using nvurisrbin ?
I am not sure if rtsp-reconnect-interval works on DS-6.0, you can check it with gst-inspect-1.0 nvurisrcbin
Are you using nvurisrbin ? : Yes
Below is the image with details.
Sorry for the long delay.
I checked the source code of nvurisrcbin, I think reconnection should not cause interruption of other streams.
When reconnecting, is the CPU/GPU usage high?
You can view the program through Nsight
Thank you for your reply. Could you share the source code? The ‘nvurisrcbin’ example code is not available with version 6.0.1, so I am using the example code from version 6.3. However, I am encountering an issue where if one stream gets disconnected, it attempts to reconnect, but the other streams also get stuck in the process.
I also use deepstream-test3. I am not sure if this is a bug in DS-6.0.
However, since DS-6.0 is no longer supported, I don’t have any good suggestions.
