Nvurisrcbin rtsp reconnect interval issue
• Hardware Platform (Jetson / GPU) Dual Nvidia A2
• DeepStream Version 6.3
• TensorRT Version 8.5
• NVIDIA GPU Driver Version (valid for GPU only) 535.129.03
• Issue Type( questions, new requirements, bugs) questions & bug
I have an issue with my deepstream pipeline that’s causing the pipeline to freeze and get stuck during runtime.
So my system runs the pgie inference in addition to 3 sgie models, system was working well over rtsp streams (average 30 streams), then we wanted to add a feature to allow for system to keep working if one or more of the rtsp streams became unavailable without stopping the pipeline and keep working with the rest and to check for the disabled ones periodically and re add them if they become available again, we tested this feature first with 4~5 cameras only and it was working fine, but when working with all the 30 streams it freezes the entire system unexpectedly, on further investigation this behavior happens with even just 10 streams or more, Currently the only parameter to change for this feature is the property itself , at first we tried 10 seconds interval then after checking some forum threads it was advised to set it to 20 or more, we tried with 20, 30, 300 but all values cause the same behaviour, also at 300 (5mins) we noticed that the system freezes even before 2 mins pass, and all the links were already up so basically the reconnect check or execution haven’t even triggered yet, please provide any guide if I’m not using this feature correctly (like what am I doing wrong or are there any other parameters/properties I need to set in order for this to work right) and/ or if there’s another method to achieve my target except for using this property
please refer to this topic1 and topic2.
