`rtsp-reconnect-interval` role
• Hardware Platform (Jetson / GPU): dPU A40.
• DeepStream Version: 6.4-triton-multiarch.
• TensorRT Version: 8.6.1.6.
• NVIDIA GPU Driver Version (valid for GPU only): 535.146.02.
• Issue Type( questions, new requirements, bugs): questions.
I use deepstream_test3 and enabled rtsp-reconnect-interval.
  • if some stream become down I can’t receive stream-eos message via bus_call
  • if all streams become down also not receive Gst.MessageType.EOS via bus_call(to quit the pipeline)
  • if all streams are down before pipeline launching also not receive Gst.MessageType.EOS via bus_call(to quit the pipeline).
What’s rtsp-reconnect-interval role in all these scenarios?
how did you do this? from the name, it is the interval value of rtsp reconnection.
Yes, use nvurisrcbin plugins instead of uridecodebin + set value of rtsp-reconnect-interval for example 10 sec for re-connect
above scenarios happened only if set value of rtsp-reconnect-interval!
if setting rtsp-reconnect-interval >0, the rtsp reconnection functionality will be activated.
if the stream is down, nvurisrcbin will try to reconnect rtsp stream.
