Is there a way to automatically reconnect to lost streams?
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 7.0
• JetPack Version (valid for Jetson only) 6.0
• TensorRT Version 10.4
Due to brief latency and connectivity issues, I lose connection with my rtsp streams (I connect to them using uridecode). I want my pipeline to automatically reconnect when the stream comes back online. Is there a code sample that shows how to do this?
There is RTSP reconnection sample in /opt/nvidia/deepstream/deepstream/sources/apps/apps-common/src/deepstream_source_bin.c
This method can only handle the RTSP connection issue when the RTSP session is alive. If there is any issue causes the error which triggers the bus error, you need to handle the bus error by yourself.
I see, I tried to make a program that automatically reconnects to a stream when it goes back online but I am not sure it is reconnecting properly due to the probe function on pgie not printing frame info after reconnection. The experiment I set was based on using a stable rtsp stream and a local one on the deepstream_rtsp code. To simulate a lost connection, I stop the local stream and start it again after sometime. Here is the code I am using:
import sys
import time
import gi
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GLib
import pyds
# --- Global State ---
pipeline = None
streammux = None
source_bins_info = {}
reconnection_success_logged = set()
class SourceInfo:
    """Helper class to store information about a source bin."""
    def __init__(self, index, uri, bin_element, muxer_sink_pad):
        self.index = index
        self.uri = uri
        self.bin = bin_element
        self.muxer_sink_pad = muxer_sink_pad
        self.reconnect_scheduled = False
        self.last_frame_num = -1 # Add this for tracking
def pgie_sink_pad_buffer_probe(pad, info, u_data):
    Analyzes metadata to verify stream reconnection and processing.
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer")
        return Gst.PadProbeReturn.OK
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    if not batch_meta:
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        # Cast the data to NvDsFrameMeta
        source_id = frame_meta.source_id
        frame_num = frame_meta.frame_num
        source_info = source_bins_info.get(source_id)
        if not source_info:
            l_frame = l_frame.next
            continue
        # If a reconnect was scheduled and we haven't logged its success yet...
        if source_info.reconnect_scheduled and source_id not in reconnection_success_logged:
            print(f"✅ SUCCESS: Source {source_id} reconnected. Processing resumed at frame number {frame_num}.")
            # Log that we've confirmed this source, to avoid repeated messages
            reconnection_success_logged.add(source_id)
        source_info.last_frame_num = frame_num
        # Optional: Print regular processing info to show the pipeline is active. Source ID different than 1 because I only want to see if
        if source_id != 1:
           print(f"  -> Processing: Source ID={source_id}, Frame Num={frame_num}")
        # Move to the next frame in the batch
def decodebin_child_added(child_proxy, obj, name, user_data):
    Callback to configure the underlying source element inside uridecodebin.
    This is crucial for setting timeouts for live streams.
    We check for 'source' as it's more generic than 'rtspsrc'.
    if 'source' in name:
        print(f"✅ Found source element: '{name}'. Applying live stream properties...")
        obj.set_property("tcp-timeout", 5 * 1000 * 1000)
        obj.set_property("latency", 2000)
        obj.set_property("drop-on-latency", True)
def cb_newpad(decodebin, decoder_src_pad, data):
    Dynamic pad callback to set the target of the source bin's ghost pad.
    caps = decoder_src_pad.get_current_caps()
    if not caps:
        caps = decoder_src_pad.query_caps()
    gststruct = caps.get_structure(0)
    gstname = gststruct.get_name()
    source_bin = data
    if gstname.startswith("video/x-raw"):
        ghost_pad = source_bin.get_static_pad("src")
        if ghost_pad.get_target():
            print("Ghost pad already has a target. Ignoring new pad.")
            return
        print(f"✅ Setting target for ghost pad: linking to '{decoder_src_pad.get_name()}'")
        if not ghost_pad.set_target(decoder_src_pad):
            sys.stderr.write("Failed to set ghost pad target.\n")
def create_source_bin(index, uri):
    Creates a Gst.Bin that contains a uridecodebin to handle a single stream.
    bin_name = f"source-bin-{index}"
    print(f"Creating bin: {bin_name} for URI: {uri}")
    nbin = Gst.Bin.new(bin_name)
    uri_decode_bin = Gst.ElementFactory.make("uridecodebin", f"uri-decode-bin-{index}")
    if not nbin or not uri_decode_bin:
        sys.stderr.write("Failed to create source bin elements.\n")
        return None
    uri_decode_bin.set_property("uri", uri)
    uri_decode_bin.connect("pad-added", cb_newpad, nbin)
    uri_decode_bin.connect("child-added", decodebin_child_added, nbin)
    Gst.Bin.add(nbin, uri_decode_bin)
    ghost_pad = Gst.GhostPad.new_no_target("src", Gst.PadDirection.SRC)
    nbin.add_pad(ghost_pad)
    return nbin
def reconnect_source(user_data):
    The core reconnection logic, now with robust error handling.
    source_info = user_data
    bin_name = source_info.bin.get_name()
    print(f"\n--- Attempting to reconnect source {source_info.index} ({bin_name}) ---\n")
    try:
        source_info.bin.set_state(Gst.State.NULL)
        streammux.release_request_pad(source_info.muxer_sink_pad)
        pipeline.remove(source_info.bin)
        # A small delay helps ensure all resources are released before re-adding
        time.sleep(0.5)
        new_source_bin = create_source_bin(source_info.index, source_info.uri)
        if not new_source_bin:
            sys.stderr.write(f"❗️ Failed to recreate source bin for index {source_info.index}.\n")
            return GLib.SOURCE_REMOVE
        pipeline.add(new_source_bin)
        sinkpad_template = streammux.get_pad_template("sink_%u")
        new_muxer_sink_pad = streammux.request_pad(sinkpad_template, f"sink_{source_info.index}", None)
        if not new_muxer_sink_pad:
            raise RuntimeError(f"❗️ Failed to get a new sink pad from streammux for source {source_info.index}.")
        srcpad = new_source_bin.get_static_pad("src")
        if srcpad.link(new_muxer_sink_pad) != Gst.PadLinkReturn.OK:
            raise RuntimeError(f"❗️ Failed to link new source bin {source_info.index} to streammux.")
        source_info.bin = new_source_bin
        source_info.muxer_sink_pad = new_muxer_sink_pad
        new_source_bin.sync_state_with_parent()
        print(f"\n✅ Reconnection logic complete for source {source_info.index}. Waiting for data... ---\n")
    except Exception as e:
        print(f"❌ CRITICAL: An error occurred during reconnection for source {source_info.index}: {e}")
    finally:
        print(f"Resetting reconnection state for source {source_info.index}.")
        source_info.reconnect_scheduled = False
=    return GLib.SOURCE_REMOVE
def bus_call(bus, message, loop):
    Callback to process messages from the GStreamer bus.
    t = message.type
    msg_src = message.src
    def find_source_bin_index_from_element(element):
        parent = element
        while parent is not None:
            for index, info in source_bins_info.items():
                if parent == info.bin:
                    return index
            parent = parent.get_parent()
        return -1 # Not found in any of our tracked source bins
    if t == Gst.MessageType.EOS:
        if msg_src == pipeline:
            print("End-of-stream received from pipeline. Quitting.")
            loop.quit()
        else:
            print(f"-> Received EOS from '{msg_src.get_name()}'")
            source_index = find_source_bin_index_from_element(msg_src)
            if source_index != -1:
                info = source_bins_info[source_index]
                if not info.reconnect_scheduled:
                    print(f"EOS is from source {source_index}. Scheduling reconnection in 5 seconds...")
                    info.reconnect_scheduled = True
                    reconnection_success_logged.discard(source_index)
                    GLib.timeout_add_seconds(5, reconnect_source, info)
    elif t == Gst.MessageType.ERROR:
        err, debug = message.parse_error()
        print(f"❗️ ERROR from element '{msg_src.get_name()}': {err.message}")
        print(f"   Debug details: {debug}")
                print(f"Error is from source {source_index}. Scheduling reconnection in 5 seconds...")
                # Reset the success log for this source
    return True
def main():
    global pipeline, streammux, source_bins_info
    stream_uris = [
        "rtsp://127.0.0.1:8552/ds-test-0",
        "rtsp://link_to_a_stable_stream" #Possible to use a video file too
    Gst.init(None)
    print("Creating Pipeline...")
    pipeline = Gst.Pipeline.new("reconnect-test-pipeline")
    streammux = Gst.ElementFactory.make("nvstreammux", "stream-muxer")
    pgie = Gst.ElementFactory.make("nvinfer", "primary-gie")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "nvvid-converter")
    sink = Gst.ElementFactory.make("fakesink", "sink")
    if not pipeline or not streammux or not pgie or not nvvidconv or not sink:
        sys.stderr.write("Failed to create core elements.\n")
        sys.exit(1)
    streammux.set_property('width', 1280)
    streammux.set_property('height', 720)
    streammux.set_property('batch-size', len(stream_uris))
    streammux.set_property('batched-push-timeout', 40000)
    streammux.set_property('live-source', 1)
    pgie.set_property('config-file-path', "config_pgie_yolo_det.txt")
    print("Adding elements to Pipeline...")
    pipeline.add(streammux)
    pipeline.add(pgie)
    pipeline.add(nvvidconv)
    pipeline.add(sink)
    print("Linking elements in the Pipeline...")
    streammux.link(pgie)
    pgie.link(nvvidconv)
    nvvidconv.link(sink)
    pgiesinkpad = pgie.get_static_pad("sink")
    if not pgiesinkpad:
        sys.stderr.write("Unable to get sink pad of pgie\n")
    else:
        pgiesinkpad.add_probe(Gst.PadProbeType.BUFFER, pgie_sink_pad_buffer_probe, 0)
        print("Added probe to PGIE sink pad.")
    print("Creating and adding source bins to pipeline...")
    for i, uri in enumerate(stream_uris):
        source_bin = create_source_bin(i, uri)
        if not source_bin:
            continue
        pipeline.add(source_bin)
        muxer_sink_pad = streammux.request_pad(sinkpad_template, f"sink_{i}", None)
        srcpad = source_bin.get_static_pad("src")
        srcpad.link(muxer_sink_pad)
        source_bins_info[i] = SourceInfo(i, uri, source_bin, muxer_sink_pad)
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", bus_call, loop)
    print("Starting pipeline...")
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except KeyboardInterrupt:
        print("Ctrl+C pressed. Exiting.")
    print("Stopping pipeline.")
    pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
    main()
I wonder what else I have to modify to properly resume getting frame info in the pgie probe or if it is possible at all.
  1. Please upgrade to DeepStream 7.1 or later version
  2. The RTSP reconnection function has been integrated in the Gst-nvurisrcbin — DeepStream documentation, you can use this element as the source. The element is open source
  3. The python sample of adding/removing sources dynamically is in /opt/nvidia/deepstream/deepstream/service-maker/sources/apps/python/flow_api/deepstream_test5_app
Thanks! I changed uridecodebin to nvurisrcbin and set it to only use TCP protocol. It seems to have worked with my problematic streams.
