gst-launch-1.0 rtspsrc location=rtsp://admin:baidu123@192.168.3.199/h264/ch1/main/av_stream ! rtph264depay ! nvv4l2decoder ! nvvideoconvert ! ‘video/x-raw,format=I420’! nvjpegenc ! multifilesink location=lss%d.jpg it is OK .
gst-launch-1.0 rtspsrc location=rtsp://admin:baidu123@192.168.3.199/h264/ch1/main/av_stream ! rtph264depay ! nvv4l2decoder ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=I420’! nvjpegenc ! multifilesink location=lss%d.jpg
add (memory:NVMM) in this pipeline ,I get error:
Setting pipeline to PAUSED …
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL …
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://admin:baidu123@192.168.3.199/h264/ch1/main/av_stream
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (open) Opened Stream
Setting pipeline to PLAYING …
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Caught SIGSEGV
^C^CSpinning. Please run ‘gdb gst-launch-1.0 1278’ to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
handling interrupt.
Why?
• DeepStream Version
• TensorRT Version
**• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)**strong text
