Nvvideoconvert framerate setting problem
GPU
• DeepStream Version
deepstream_sdk_v4.0.1
NVIDIA RTX A2000 12GB
NVIDIA-SMI 510.108.03 Driver Version: 510.108.03 CUDA Version: 11.6
bugs
when i run this pipeline:
gst-launch-1.0 v4l2src ! nvvideoconvert ! videorate max-rate=2147483647 ! capsfilter caps=‘video/x-raw(memory:NVMM),framerate=1/1’ ! nvvideoconvert ! videoconvert ! fakesink --gst-debug=1
I got this error:
setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
…/libs/gst/base/gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.001682896
Setting pipeline to NULL …
Freeing pipeline …
but when i set framerate=5/1, it’t work well
gst-launch-1.0 v4l2src ! nvvideoconvert ! videorate max-rate=2147483647 ! capsfilter caps=‘video/x-raw(memory:NVMM),framerate=5/1’ ! nvvideoconvert ! videoconvert ! fakesink --gst-debug=1
Pipeline works no matter what framerate is set
are you using DS v4.0.1? it is a too old version, can you reproduce this issue on the latest version 6.2?
I used version 6.2 and this problem still exists
could you share more logs? please do “export GST_DEBUG=6” first to modify Gstreamer’s log level, then run again, you can redirect the logs to a file.
please refer to this command:
gst-launch-1.0 -v v4l2src device=/dev/video0 ! videorate ! video/x-raw,framerate=1/1 ! nvvideoconvert ! videorate max-rate=2147483647 ! capsfilter caps='video/x-raw(memory:NVMM),framerate=1/1, format=NV12 ’ ! fakesink --gst-debug=1
