• Hardware Platform (Jetson / GPU) TX2
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.3
• TensorRT Version 7.1
• Issue Type( questions, new requirements, bugs) Bugs : Deepstream pipeline crashes with “Error: gst-stream-error-quark: Internal data stream error. (1): gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstPylonSrc:usb-cam-source:
streaming stopped, reason error (-5)”
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) I am using Adlink NEON-2000-JT2 vision camera that has a basler camera connected to Jetson TX2 module. I am using pylonsrc gstreamer plugin to connect the camera to deepstream plugin. When I run this pipeline : gst-launch-1.0 -v pylonsrc binningv=2 binningh=2 ! fpsfilter ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=NV12’ ! m.sink_0 nvstreammux name=m batch-size=1 width=1296 height=972 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/My_app/detector_config.txt ! nvtracker ll-lib-file = /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so tracker-width=640 tracker-height=384 ! nvdsanalytics config-file=/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/My_app/config_nvdsanalytics.txt ! nvvideoconvert ! nvdsosd process-mode=2 display-bbox=1 ! nvegltransform ! nveglglessink sync=False . My application works for a while and crashes with following error Error: gst-stream-error-quark: Internal data stream error. (1): gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstPylonSrc:usb-cam-source:
streaming stopped, reason error (-5).
